Samsung Xpress MFP SL-M2885 - Setting the Paper Size and Type
After loading paper in the paper tray, set the paper size and type using the control panel buttons.
The paper setting in the printer and driver must match to print without a paper mismatch error.
To change the paper setting set in the printer, from the Samsung Easy Printer Manager select (Switch to advanced mode) > Device Settings.
If the printer supports a display screen, set it by using the (Menu) button on the control panel.
Then, set the paper type from the Printing Preferences window > Paper tab > Paper Type, see Opening printing preferences.
It might be necessary to press OK to navigate to lower-level menus for some models.
  1. Select (Menu) > System Setup > Paper Setup > Paper Size or Paper Type on the control panel.
  2. Select the appropriate tray and the required option.
  3. Press OK to save the selection.
To use special-sized paper, such as billing paper, select the Paper tab > Size > Edit... and set Custom Paper Size Settings in the Printing Preferences, see Opening printing preferences.
Using the output support
The surface of the output tray might become hot if when printing many pages at one. Make sure that not to touch the surface, and do not allow children near it.
The printed pages stack on the output support, and the output support will help the printed pages to align. Unfold the output support.
Figure : Output support
