Samsung Xpress MFP SL-M2070, SL-M2071 - Monitoring the Supplies Life
If you experience frequent paper jams or printing problems, check the number of pages the printer has printed or scanned. Replace the corresponding parts, if necessary.
Use these steps to check the supplies life.
  1. Select Menu > System Setup > Report > Supplies Info. on the control panel.
  2. Select the option you want and press OK.
    • Total: Displays the total number of pages printed.
    • ADF Scan: Displays the total number of pages printed using the document feeder.
    • Platen Scan: Displays the total number of pages printed using the scanner glass.
    • Supplies Info.: Prints the supply information page.
  3. Press Stop/Clear to return to ready mode.
