The following instructions show how to load paper into the tray.
Open the tray.
Figure : Tray open
Flex or fan the edge of the paper stack to separate the pages before
loading papers.
Figure : Flex or fan paper
Adjust the tray size to the media size being loading, see Tray overview. Place the paper with the side to print facing
up, then open the output tray.
Figure : Adjust tray
Squeeze the paper width guide and slide it to the edge of the paper stack
without causing it to bend.
Figure : Adjust paper guides
- Do not push the paper width guide too far causing the media to warp.
Not adjusting the paper width guide might cause paper jams.
Figure : Adjust width guides
Do not use a paper with a leading-edge curl, it might cause a paper jam or
the paper can be wrinkled.
Figure : Straight paper
- When printing a document, set the paper type and size for the tray, see Setting the paper size and type.
