HP Printers - Printing with Apple AirPrint (Mac)
This document is for HP AirPrint-compatible printers and Mac computers with macOS and OS X 10.7 (Lion) and later.
AirPrint is a built-in printing solution for Mac computers and mobile devices. You can print from most apps that have a print feature.
For steps to use AirPrint for Apple iPhones or iPads, go to HP Printers - Printing with Apple AirPrint (iOS)
On iOS and macOS, most HP printers work with Apple AirPrint to provide full-quality printing without the need to download or install drivers. For additional functionality, please download the HP Smart app from the App Store for iPhone and iPad or the Mac App Store.
Step 1: Connect the printer to the Mac or your network
To use AirPrint, connect the printer to the Mac or to the same network that the Mac is connected to.
  1. Turn on the printer, and then connect it to the network or the computer, depending on how you want to use your printer.
    • Wireless connection for printers with touchscreen or LCD menu control panels: On the printer, select the Setup, Network, or Wireless menu, select Wireless Setup Wizard, and then follow the on-screen instructions to connect the printer.
    • Wireless connection for printers with buttons only: Press and hold the Wireless button for three seconds until the wireless light blinks. Press the WPS button on your router, and then wait while the printer connects to the network.
    • USB connection: Connect the cable to the USB port on the rear of the printer and to an available port on the computer.
    • Wired (Ethernet) network connection: Connect the network cable to the printer Ethernet port and to an available port on the router or access point. At the port, the green light should be steady and the orange activity light should blink.
    For a guided printer connection setup, go to HP Customer Support - Software and Driver Downloads, enter your printer model if prompted, click Download next to HP Easy Start or the full feature driver under Driver-Product Installation Software, and then open the file to begin the printer setup.
  2. Open a document or photo, click File, and then click Print.
    • If your printer is listed in the Printers menu, click the printer name and try to print. If you can print, the setup is complete.
    • If your printer is not listed in the Printers menu, it might display under Nearby Printers. Continue to the next step if the printer does not display in either list.
Step 2: Add the AirPrint printer to the Mac printer queue
Confirm you are using AirPrint by adding the printer in System Preferences.
  1. Click the Apple menu, click System Preferences, and then click Print & Scan or Printers & Scanners.
    Figure : Example of the Printers & Scanners window
  2. Check if your printer name displays in the Printers list, and then do one of the following steps.
    • If your printer is listed, remove and re-add the printer to confirm it is set up for AirPrint. Click the printer name, click the minus sign to delete the printer, click the plus sign , click Add Printer or Scanner, click the printer name and then continue to the next step.
    • If your printer is not listed, click the plus sign, click Add Printer or Scanner, click the name of your printer, and then continue to the next step.
    • If your printer is not listed in the Add Printer or Scanner window, go to the Frequently asked questions in this document to resolve connection issues, try to add the printer again, and then continue to the next step.
  3. Confirm AirPrint or Secure AirPrint displays in the Use or Print Using menu, and then click Add.
    Figure : AirPrint displays in the Use menu
    Select AirPrint from the Use menu
  4. Open a document or photo, click File, and then click Print.
Review the list of frequently asked questions about printing from a Mac computer with Apple AirPrint.
