Samsung Xpress MFP SL-M2070, SL-M2071 - Loading Originals
Use the scanner glass or the document feeder to load an original for copying, scanning, and sending a fax.
Illustrations on this user’s guide might differ from the printer depending on its options or models. Check the printer type, see Front view.
On the scanner glass
Use the scanner glass to copy or scan originals. It is possible to get the best scan quality, especially for colored or gray-scaled images. Make sure that no originals are in the document feeder. If an original is detected in the document feeder, the printer gives it priority over the original on the scanner glass.
  1. Lift and open the scanner lid.
    Figure : Open lid
  2. Place the original face down on the scanner glass. Align it with the registration guide at the top left corner of the glass.
    Figure : Paper alignment
  3. Close the scanner lid.
  • Leaving the scanner lid open while copying might affect copy quality and toner consumption.
  • Dust on the scanner glass might cause black spots on the printout. Always keep it clean, see Cleaning the machine.
  • When copying a page from a book or magazine, lift the scanner lid until its hinges are caught by the stopper and then close the lid. If the book or magazine is thicker than 30 mm, start copying with the scanner lid open.
  • Be careful not to break the scanner glass. Injury might occur.
  • Do not put hands while closing the scanner lid. The scanner lid might fall on your hands and cause injury.
  • Do not look at the light from inside of the scanner while copying or scanning. It is harmful to eyes.
In the document feeder
Using the reverse automatic document feeder, up to 40 sheets of paper (80 g/m2, 20 lb. bond) can be loaded for one job.
  1. Flex or fan the edge of the paper stack to separate the pages before loading originals.
    Figure : Flex or fan
  2. Load the original face up into the document feeder input tray. Make sure that the bottom of the original stack matches the paper size marked on the document input tray.
    Figure : Load paper
  3. Adjust the document feeder width guides to the paper size.
    Figure : Paper guides
    Dust on the document feeder glass might cause black lines on the printout. Always keep the glass clean, see Cleaning the machine.
