HP Spectre x2 - 12-a050sa (ENERGY STAR) Product Specifications
P0T78EA
Intel® Core™ M3-6Y30 with Intel® HD Graphics 515 (900 MHz, up to 2.2 GHz, 4 MB cache, 2 cores)
4 GB DDR3L SDRAM (onboard)
Video graphics
128 GB M.2 SSD
30.5 cm (12") diagonal WUXGA UWVA BrightView WLED-backlit (1920 x 1280)
Keyboard
Full-size island-style backlit
Pointing device
802.11a/b/g/n/ac (2x2) and Bluetooth® 4.0 combo (Miracast compatible)
1 headphone/microphone combo; 2 USB 3.0 (Type-C)
Dimensions (W x D x H)
30.3 x 20.9 x 0.8 cm (tablet); 30.3 x 20.9 x 1.31 cm (tablet and base)
0.82 kg (tablet); 1.19 kg (tablet and base)
45 W AC power adapter
3-cell, 42 Wh Li-ion polymer
5 MP HP TrueVision Full HD Webcam (front-facing) with integrated dual digital microphones; Intel® RealSense™ 3D Camera with dual digital microphone (rear-facing)
Bang & Olufsen; Quad speakers
HP Lounge
Pre-installed software
Netflix; Skype
