    Fix Windows 10 Update Issues
HP Ink Tank 410 Printers - Wireless Printer Setup (Windows)
This document is for computers with Windows and HP Ink Tank Wireless 410, 411, 412, 415, 416, 418, and 419 printers.
Install the print drivers and other software for your printer to use it on a wireless network. If you have more than one computer on the network, install the software on each computer that you plan to use with the printer.
Step 1: Prepare for installation
Before installing the printer software and connecting to your wireless network, check the requirements, turn on the computer and the router, and set up the printer.
  1. To use your printer on a wireless network, you need the following items:
    • A computer connected to your wireless network
    • Internet access: HP recommends broadband Internet access such as cable or DSL for software downloads, using Web Services, and getting printer updates.
  2. Make sure the router and computer are turned on, and that the computer is connected to the same wireless network to which you want to connect the printer.
  3. Set up the printer, load paper into the input tray, and install the ink cartridges. For more information about setting up the printer, go to First Time Printer Setup.
  4. Turn on the printer and place it close to the computer and within range of the router during the wireless setup.
Step 2: Restore default wireless settings on the printer
Reset the wireless settings on the printer so the connection completes successfully.
  1. On the printer control panel, make sure the wireless light is blinking and the Power button light is bright. If the light is not bright, press the Power button to wake the printer from sleep mode.
  2. If the wireless light is not blinking, press and hold the Wireless button and the Cancel button at the same time for 3 seconds.
    The wireless light blinks. Repeat these steps if the wireless light does not blink.
  3. Immediately continue to the next step to install the software. You have approximately 120 minutes to complete the software setup using the HP auto wireless connect feature.
Step 3: Install the printer software
On the computer you want to print from, start the software installation, and then download and install the HP full feature print driver. It contains the wireless print drivers, as well as HP Printer Assistant software for scanning and other printer management functions.
  1. Disconnect any USB cables from the printer.
  2. Go to 123.hp.com/IT410, and then click Download to download and run HP Easy Start.
  3. When prompted to select your printer, click My Printer Is Not Shown.
    Clicking My Printer Is Not Shown
  4. Click Continue, and then select Wireless network (if applicable).
    Selecting Wireless network (if applicable)
  5. Click Continue, and then follow the on-screen prompts to set up your printer on a wireless network.
If the download fails, go to HP Customer Support - Software and Driver Downloads, click Printer, type your printer model number, and then click Submit. Confirm your version of Windows is correct. Under the Driver-Product Installation Software heading, click Download for the full software package, or click Basic Drivers for other driver options.
Review these frequently asked questions about setting up the wireless network connection.
