HP Z22n G2 21.5-inch Display - Specifications
Panel
Specification
Display panel type
IPS
Display size (diagonal)
21.5 inches
54.61 cm (21.5 in) widescreen
Micro-edge bezel
Yes
3 sided
Panel hardness
3H
Panel active area (W x H)
47.60 x 26.77 cm (18.74 x 10.54 in)
Aspect ratio
16:9
Viewing angle (typical CR > 10)
Up to 178° horizontal (10:1 minimum contrast ratio)
Up to 178° vertical (10:1 minimum contrast ratio)
Brightness
250 cd/m2
Static contrast ratio
1,000:1 static (typical)
Dynamic contrast ratio
10,000,000:1 (typical)
Response times
5 ms Gray to Gray
Default is 14.0 ms and can be adjusted to as low as 5.4 ms in the display menu. See user guide for more information.
Pixel pitch
0.24795 mm
Pixels Per Inch (PPI)
102
Default color temperature
sRGB D65 (6500 K)
Backlight lamp life
30,000 hours minimum (to half brightness)
Panel bit depth
8-bit (6-bit with A-FRC) 16.7 Million colors
Color gamut
99% sRGB
Anti-glare panel
Yes
Haze 25%
Flicker free
Yes
Low blue light capable
Yes
User selectable in On-screen Display (OSD) menu
Actual performance varies.
User controls
Specification
Buttons or switches
Menu/OK
Minus button/Down/Color Control
Plus button/Up/Viewing Mode Menu
Exit/Back/Next Active Input
Power
User-assignable function buttons
10
Languages
10 (English, Spanish, German, French, Italian, Dutch, Portuguese, Japanese, Simplified Chinese, and Traditional Chinese)
On-screen Display (OSD) user controls
Brightness, Contrast, Color Control, Input Control, Image Control, Power Control, Menu Control, Management, Language, Information, and Exit
Signal interface/performance
Specification
Native resolution/timing
1920 x 1200 at 60 Hz (preferred)
Supports up to 75 Hz refresh for some video modes. The video card of the connected PC must be capable of supporting 75 Hz.
Maximum resolution
Recommended resolution
Preset graphic modes/Supported resolutions
640 x 480 at 60 Hz, 75 Hz
720 x 400 at 70 Hz
800 x 600 at 60 Hz, 75 Hz
1024 x 768 at 60 Hz, 75 Hz
1280 x 720 at 60 Hz
1280 x 800 at 60 Hz
1280 x 1024 at 60 Hz, 75 Hz
1440 x 900 at 60 Hz
1600 x 900 at 60 Hz
1680 x 1050 at 60 Hz
1920 x 1080 at 60 Hz, 75 Hz
Pixel clock
180 MHz (maximum)
Vertical scan range
50 - 75 Hz
Horizontal scan range
30 - 84 kHz
Color management
Specification
sRGB
95% sRGB
Factory color calibrated
Yes
Factory calibration accuracy
White point maximum
3.0 ∆E 2000
Grayscale average (255 levels) maximum
3.0 ∆E 2000
Gamma target tolerance (2.2 for sRGB, 2.4 for BT.709)
+/- 0.1
X-Rite ColorChecker average maximum
3.0 ∆E 2000
Video/other inputs
Specification
Connector types
(1) DisplayPort (DP) 1.2
(1) HDMI 1.4
(1) VGA
HDCP support for DisplayPort and HDMI
USB ports
(3) USB 3.0
(2) Downstream and (1) Upstream
Ergonomics
Specification
Color of monitor bezel and stand
Space Silver head
Black Pearl chin
Die-Cast Aluminum base with Black Pearl paint
Plug and play
Yes
Tilt range
-5° to +22° vertical
Swivel
+/- 45
Pivot
Yes
Pivot (clockwise and counter clockwise)
Height adjustment range
Yes
0 to 150 mm
4-Way comfort adjust
Adjustable height, tilt, swivel and pivot
Integrated quick release
LCD monitor mounting solution
Quickly and securely attaches an LCD monitor to a variety of stands, brackets, arms or wall mounts
The HP Quick Release has been designed to support a maximum of up to 10.9 kg (24 lb) for all devices mounted. Because mounting surfaces vary widely and the final mounting method and configuration might vary, mounting fasteners are not supplied (other than the VESA-compliant screws). HP recommends that you consult with a qualified engineering, architectural or construction professional to determine the appropriate type and quantity of mounting fasteners required for your application and to ensure that your mounting solution is properly installed to support applied loads.
Cable management
Easy concealment and effortless routing of cables through the cable management tunnel at the base of the column
VESA mounting
Yes
100 mm
Security lock-ready
Yes
Zero bright dot warranty
Yes
The HP pixel policy allows no bright sub-pixel defects for this display.
Power
Specification
Power supply
Internal
Input power
100 - 240 VAC 50/60 Hz
Maximum power
30 W
Maximum power is measured with monitor at maximum brightness and with USB ports loaded at 100% of maximum.
Typical power
17 W
Default power is measured with factory defaults, including factory default brightness and USB ports loaded at 25% of maximum.
Energy saving/standby mode
0.5 W
Power cable length
1.9 m (6.23 ft)
Physical specifications
Specification
Dimensions (W × D × H)
Unpacked with stand (highest setting)
48.82 x 20.50 x 44.96 cm (19.22 x 8.07 x 17.7 in)
Packaged
56.90 x 35.05 x 26.92 cm (22.4 x 13.8 x 10.6 in)
Head only
48.82 x 4.32 x 29.34 cm (19.22 x 1.7 x 11.55 in)
Base area footprint
23.70 x 1.09 x 20.50 cm (9.33 x 0.43 x 8.07 in)
Unpacked
5.3 kg (11.68 lb)
Packed
7.6 kg (16.75 lb)
Head only
2.8 kg (6.17 lb)
What's in the box?
Specification
Monitor and accessories
AC power cord, 1.9 m (6.23 ft)
DisplayPort (DP) cable, 2.0 m (6.56 ft)
USB 3.0 Type-B to A cable 1.8 m (5.91 ft)
Documentation
CD (includes user guide, warranty, and drivers)
HP Display Assistant software
HP Display Assistant is a software utility that enables theft deterrence and allows monitor adjustment, color calibration, and security/asset management using the Display Data Channel Command Interface (DDC/CI) protocol of the connected PC or workstation.
Environmental
Specification
Temperature
Operating
5° to 35° C (41° to 95° F)
Non-operating
-20° to 60° C (-4° to 140° F)
Humidity
Operating
20% to 80% non-condensing
Non-operating
5% to 95%, 38.7° C maximum wet-bulb
Altitude
Operating
0 to 5,000 m (0 to 16,400 ft)
Non-operating
0 to 12,192 m (0 to 40,000 ft)
Arsenic-free display glass
Yes
White LED backlights
Yes
Mercury-free display backlighting
Yes
Low halogen
Yes (except cables)
External power supplies, power cords, cables and peripherals are not low halogen. Service parts obtained after purchase may not be low halogen.
Eco-label certifications & declarations
ENERGY STAR
EPEAT Gold (registration varies by country/region)
CEL Grade 1
Microsoft WHQL certification (Windows 7, 8 and 10)
TCO certified edge
SmartWay transport partnership (NA only)
CE
CB
MSIP
Mexico COC
ICES
ISO 9241- 307
CU
cTUVus
ISC
CCC
VCCI
FCC
BSMI
WEEE
RCM
ErP
KC/E-Standby
SEPA
GS
TUV-S
Australian-New Zealand MEPS
PSB
Vietnam MEPS
Country: Flag Thailand
