HP VH240a Display - Product Specifications
The HP VH240a is a 60.5 cm (23.8 in) Display.
Figure : VH240a Display
The VH240a Display
2DS80AA
Technical specifications
LED feature
Specification
Display size
60.5 cm (23.8 in) diagonal
Display type
IPS
Brightness
250 nits
Pixel pitch
0.275 mm x 0.275 mm
92.55 PPI
Color gamut
72% sRGB
Color support
Up to 16.7 million colors with the use of FRC technology
Frequency
Horizontal: 30-80 kHz
Vertical: 50-60 Hz
Inputs
1 VGA
1 HDMI
HDCP support on digital inputs
Viewing angle
Horizontal viewing angle (typical): 178 degrees
Vertical viewing angle (typical): 178 degrees
Resolution (recommended)
1920 x 1080 (Full HD)
Aspect ratio
16:9
Static contrast ratio
Up to 1000:1
Dynamic contrast ratio
Up to 10,000,000:1
Response time
5 ms GtG
Power consumption
27 W max
Tilt
-5 to +30 degrees
Dimensions
W x D x H (unpacked):
53.8 x 21.8 x 50.0 cm (21.2 x 8.6 x 19.7 in)
Unpacked: 4.7 Kg (10.3 lb)
