    Fix Windows 10 Update Issues
Samsung Xpress Color MFP SL-C480 - Supplies and Maintenance Parts
Available supplies
When supplies reach the end of their lifespans, the following supplies can be ordered for the machine:
Type
Average yielda
Part name
Toner cartridge
Average continuous black cartridge yield: Approx. 1,500 standard pages (black)
Average continuous color cartridge yield: Approx. 1,000 standard pages (yellow, magenta, cyan)
K404 (CLT-K404S): Black
C404 (CLT-C404S): Cyan
M404 (CLT-M404S): Magenta
Y404 (CLT-Y404S): Yellow
Imaging unit
Approx. 16,000 imagesb
CLT-R406
Waste toner container
Approx. 7,000 imagesb
CLT-W406
a. Declared yield value in accordance with ISO/IEC 19798. The number of pages may be affected by operating environment, printing interval, graphics, media type and media size.
b. Image counts based on one color on each page. Printing documents in full color (Cyan, Magenta, Yellow, Black), the life of this item will be reduced by 25%.
Depending on the options, percentage of image area and job mode used, the toner cartridge’s lifespan might differ.
When purchasing new toner cartridges or other supplies, these must be purchased in the same country as the machine being used. Otherwise, new toner cartridges or other supplies will be incompatible with the machine due to different configurations of toner cartridges and other supplies per the specific country conditions.
  • The toner cartridge included in the printer/all-in-one product that was purchased is not available for sale and is not guaranteed to be compatible with any other printer.
  • Samsung does not recommend using non-genuine Samsung toner cartridge such as refilled or remanufactured toner. Samsung cannot guarantee non-genuine Samsung toner cartridge's quality. Service or repair required because of using non-genuine Samsung toner cartridges will not be covered under the machine’s warranty.
Available maintenance parts
Replace the maintenance parts at specific intervals to keep the machine in the best condition, and to avoid print quality and paper feeding problems resulting from the worn-out parts. Maintenance parts are mostly rollers, belts and pads. However, the replacement period and parts might differ depending on the model. Replacing maintenance parts can be performed only by an authorized service provider, dealer, or the retailer where the machine was purchased. To purchase maintenance parts, contact the retailer where the machine was purchased. The replacement period for the maintenance parts is informed by the Samsung Printer Status program. Or on the UI (user interface) if the machine supports a display screen. The replacement period varies based on the application software, paper type, paper size, and job complexity.
