This document is for HP Color LaserJet Pro M154a and M154nw printers.
- ${title}
- ${title}
- ${title}
- ${title}
HP Color LaserJet Pro M154 Printers - Fixing Poor Print Quality
The quality of a printed document is not as expected. The procedures in this document should help with print quality problems such as smeared, fuzzy, dark, or faded print, and loose, partially missing, or scattered toner.
Step 1: Use genuine HP toner cartridges
HP recommends that you use genuine HP ink or toner supplies. HP cannot guarantee the quality or reliability of non-HP or refilled cartridges. If you do not use genuine HP cartridges, the steps in this document might not resolve the issue. To check the authenticity of your cartridges, go to the HP anti-counterfeit webpage (in English).
Print another page. If using genuine HP toner cartridges did not resolve the issue, continue to the next step.
Step 2: Check the paper
The quality and type of paper can affect the print job. Follow these guidelines to make sure the paper is appropriate. If it is not, load an appropriate paper type.
Use paper designed for HP LaserJet printers. Do not use paper designed only for inkjet printers.
Do not use paper that is too rough. Smoother paper might result in better print quality.
After loading appropriate paper in the tray, print another page. If the issue persists, continue to the next step.
Step 3: Check the toner level
Check the estimated toner level in the printer software.
note:The toner supply level and the percentage of toner cartridge life remaining provide estimates for planning purposes only. When the toner level is low, consider having a replacement toner cartridge available. You do not need to replace toner cartridges until the print quality becomes unacceptable.
If the toner cartridge is not low, skip to the step to check the EconoMode setting.
If the toner cartridge is low, continue to the next step to replace the toner cartridge.
Step 4: Replace a low or empty toner cartridge
If the toner cartridge is critically low or empty, replace it.
Open the front door.Figure : Opening the front door
Grasp the blue handle on the toner cartridge drawer, and then pull out the drawer.Figure : Pulling out the toner cartridge drawer
Grasp the handle on the toner cartridge, and then pull the toner cartridge straight up to remove it.Figure : Removing the toner cartridge
Remove the new toner cartridge package from the box, and then pull the release tab on the packaging shell.Figure : Pulling the release tab on the packaging
Remove the toner cartridge.
Do not touch the green imaging drum on the bottom of the toner cartridge. Fingerprints on the imaging drum can cause print defects.Figure : Removing the toner cartridge -
Grasp both ends of the toner cartridge, and then gently rock the toner cartridge back and forth to distribute the toner.Figure : Gently rocking the toner cartridge back and forth
Insert the new toner cartridge into the drawer. Make sure the color chip on the toner cartridge matches the color chip on the drawer.Figure : Inserting the toner cartridge into the printer
Repeat these steps for other toner cartridges.
Push the toner cartridge drawer into the printer.Figure : Pushing the toner cartridge drawer into the printer
Close the front door.
Print another page. If replacing the toner cartridge did not resolve the issue, continue to the next step.
Step 5: Check the EconoMode setting
EconoMode is a print setting that uses less toner. However, using EconoMode can reduce print quality. If the entire page is too dark or too light, the EconoMode setting might be enabled.
note:HP does not recommend the full-time use of EconoMode. If EconoMode is used full time, the toner supply might outlast the mechanical parts in the toner cartridge.
Print another page. If turning off the EconoMode setting did not resolve the issue, continue to the next step.
Step 6: Check print settings
Sometimes the print settings can affect print quality. Check the print settings to make sure they are appropriate for your print job.
Print another page. If changing the print settings did not resolve the issue, continue to the next step.
Step 7: Print a cleaning page
Cleaning the printing mechanism and printing path inside the printer might resolve issues like repeating dots, fuzzy print, or smeared toner.
Print another page. If printing a cleaning page did not resolve the issue, continue to the next step.
Step 8: Inspect the toner cartridges
Examine the toner cartridge imaging drums and memory chips for damage.
Examine the memory chip for damage.Figure : Location of the memory chip
If the memory chip is damaged, refer to the previous steps in this document to replace the toner cartridge.
If the memory chip is not damaged, continue with these steps.
Examine the surface of the imaging drum.
Do not touch the imaging drum. Fingerprints on the imaging drum can cause print quality problems.Figure : Location of the imaging drum-
If you see any scratches, fingerprints, or other damage on the imaging drum, refer to the previous steps in this document to replace the toner cartridge.
If the imaging drum is not damaged, continue with these steps.
Insert the new toner cartridge into the drawer. Make sure that the color chip on the cartridge matches the color chip on the drawer.Figure : Inserting the toner cartridge
Repeat these steps for the other toner cartridges.
Print another page. If the issue persists, continue to the next step.
Step 9: Service the printer
Service or replace your HP product if the issue persists after completing all the preceding steps.
Go to Contact HP Customer Support to schedule a product repair or replacement. If you are in Asia Pacific, you will be directed to a local service center in your area.
To confirm your warranty status, go to HP Product Warranty Check. Repair fees might apply for out-of-warranty products.
note:Keep a print sample that shows the problem. If the printer, imaging drum, or toner cartridges are replaced under warranty, the support agent might request the print sample.
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Thailand
- ${title}
hp-hero-support-search
- ${title}
