Samsung Laser Printers - Supported Paper Types
Samsung printers have specific paper (media) types that can be used, but these vary depending on the printer model. For a list of recommended paper for your printer model, including envelopes, labels, card stock, transparencies, and glossy paper, refer to the user manual. If you don't have the user manual, follow the steps below to find the information for your specific printer model.
Samsung recommends against using heavy, glossy paper in any Samsung printer. Most printers support 16 to 24 lb. paper in the main tray and 16 to 43 lb. paper in the manual tray. Heavy, glossy paper can cause internal damage to your printer which can void the printer warranty.
Download the printer manual
Use these steps to download your printer manual.
  1. Go to support.hp.com and type in your printer model into the search box, then click the search button.
  2. Click User Guides.
  3. Click on the title of the user manual to open it.
