    We are upgrading our website
Samsung Multifunction Laser Printers - Send a Fax From the Computer
Before sending a fax, make sure the phone line is connected to the Line Port on the back of the printer to the telephone wall jack. The printer port will look like the example below:
Figure : Example of fax
To send a fax from your computer, the Samsung Network PC Fax program must be installed. This program is automatically installed when you install the printer driver.
Send a fax from the PC
Use these steps to send a fax from the PC.
  1. Open the document to fax. (For this set of directions, a Microsoft Word document in Windows 7 is used as an example.)
  2. Click File.
    Figure : Click File
  3. Click Print from the File menu. The Print window displays. (It might look different from the image below depending on the application.)
    Figure : Click Print
  4. Click the printer model name. An expanded list of all printers opens.
    Figure : Click the printer name
  5. Click Samsung Network PC Fax from the list of printers. (You might need to scroll down to find it.)
    Figure : Click Samsung Network PC Fax
  6. Click Print.
  7. The Fax Options screen opens. This is the last screen before the fax sends.
    1. Enter the phone number of the fax recipient.
    2. Choose from the other options:
      • Fax Quality
      • Original Type (whether the fax has photos only, text only, or both)
      • Cover Page
      • Notify me on delivery (check the box to know when the fax is received)
    3. Click Preview to view how the delivered fax will look.
    4. Click Send to deliver the fax.
    Figure : Fax options screen
    The fax is now delivered. If the check box Notify me on delivery was selected, you will receive notification once the fax is delivered to the recipient.
If the fax fails to send, make sure the phone line is connected securely into the phone line port and that there is a dial tone if used with another phone.
