Samsung Laser Printers - How to Print with Mopria
Mopria Print Service is a mobile printing solution that enhances the new print functionality on any Android phone or table (Android version 4.4 or later). With this service, users can connect and print to any Mopria-certified printer on the same network as a mobile device without additional set-up. Many native Android apps support printing, including Chrome, Gmail, Gallery, Drive, and Quickoffice.
  • Only Mopria-certified printers can use the Mopria feature. Go to Certified Products (in English) on the Mopria website, to check whether your printer is supported.
  • Check the box that the printer arrived in for the Mopria-certified logo.
  • Make sure the printer and mobile device are connected to the same network and the communication is available.
