Samsung Multifunction Laser Printers - How to configure scan to a Windows computer using Easy Printer Manager
Before scanning from a printer to a Windows computer, configure the Scan to PC Settings in Samsung Easy Printer Manager.
To set up the Scan to PC Settings in Samsung Easy Printer Manager, follow these steps:
  1. Make sure that the latest print and scan driver are installed.
    To download the latest drivers and software, go to Software and Drivers, and then type your printer model in the text box to find your printer driver.
  2. In the Windows taskbar, right-click the Samsung Easy Printer Manager icon (), and then open Samsung Easy Printer Manager
    Figure : Samsung Easy Printer Manager
  3. In the Samsung Easy Printer Manager, select your printer from the Printer List, and then click Scan to PC Settings.
    Figure : Scan to PC Settings
  4. Select the Enable Scan from Device Panel check box, and then click Save.
    Figure : Enable Scan from Device Panel
  5. In the Account Information for Scan, type your scan ID and password, and then click OK.
    To view your Scan ID information, see the name that displays on the printer as a Network PC.
    A password is optional.
    Figure : Account Information for Scan
  6. Select a desired option for the following settings in the Basic tab for the scanned image.
    If any of the options are not available or grayed out, make sure to reinstall the scan driver. To download the latest drivers and software, go to Software and Drivers.
    • Scan Settings
      • Image Type
      • Resolution
      • Scan Size
      • ADF Duplex
      • Original Type
      • Darkness
        Figure : Scan Settings
    • File Settings
      • Save To
      • Format
      • OCR Language
      • Delete original image after OCR
        Figure : File Settings
    • Actions after Saving
      • Notify me when complete
      • Open with default application
      • E-mail
      • None
        Figure : Actions after Saving
  7. Click Save after selecting the desired options to complete the scan configuration.
  8. Click "X" located at the top-right corner of the window to exit the Samsung Easy Printer Manager.
