Samsung Laser Printers - Uninstall a Printer in Windows 8
When the printer status is not correct or the printer will not print anything from the computer, completely uninstalling the printer and then reinstalling it might fix the issue.
Use these steps to uninstall the printer in Windows 8.
  1. Press the Windows and X keys on the keyboard at the same time.
    Figure : Press the Windows and X keys
  2. Click Control Panel.
    Figure : Click Control Panel
  3. Click View devices and printers.
    Figure : Control Panel menu
  4. Select the printer to uninstall, and click Remove device at the top of the window.
    Figure : Devices and Printers menu
  5. A message displays to confirm the printer uninstall. Click Yes.
    Figure : Click Yes to uninstall printer
  6. After removing the printer, remove the printer driver as well. Press the Windows and X keys on the keyboard at the same time.
  7. Click Programs and Features.
    Figure : Click Programs and Features
  8. In the Programs and Features menu, click on the model printer driver and then click Uninstall.
    Figure : Click on the model printer driver
  9. A message displays to confirm the driver uninstall. Click Yes and the installation wizard opens.
    Figure : Click Yes to remove printer driver
  10. In the installation wizard, select all the components in the list and then click Next.
    Figure : Select the software to remove
  11. The printer driver is now uninstalled. Click Finish to close the installation wizard.
    Figure : Click Finish
After uninstalling the printer, the printer no longer displays in the Devices and Printers list. Go to Software and Driver Downloads and enter your model printer into the search text box to download the latest driver.
