Samsung Laser Printers - How to Install a Printer Driver via a USB in Windows
The Samsung Printer Software Installer is a web-based installer that will download and install the printer drivers and software required for Samsung printers.
If you have not installed the print driver yet, go to Software and Driver Downloads and enter your model printer into the search text box to download the latest driver.
Use these steps to install the printer driver via USB.
  1. If you have not installed the print driver yet, go to Software and Driver Downloads and enter your model printer into the search text box to download the latest driver.
  2. Select the box beside I have reviewed and accept the installation agreements, and then click Next.
    Figure : Example of selecting the installation agreement
    Image shows where to select for installation agreement
  3. Select USB connection, and then click Next.
    Figure : Example of selecting USB connection type
    Image shows selecting USB connection
  4. The installer searches for any USB connected printers.
    If you receive a No Printer Found error, try these steps, and then click Search again:
    • Make sure the USB is fully inserted into the back of the printer, and then plugged into a working USB port of the computer.
    • Try a different USB cable and make sure the cable is shorter than 6 feet.
    • Verify the printer is powered on.
  5. Select all the components needing to be installed, and then click Next.
    Figure : Example of selecting components needing to be installed
    Image shows selecting software to be installed
  6. A progress bar shows components being installed. Click Next once the bar is full.
    Figure : Example of progress bar installing software components
    Image shows progress bar installing software components
  7. Setup is now complete. Select Print a test page to verify connection is successful, and then click Finish to close the wizard.
    Figure : Example of Setup completed
    Image shows select Print a test page to test connectivity
    If Start Easy Eco Driver before printing job is checked, before every print job, the Easy Eco Driver software shows a preview of what you are printer and allows toner/paper option adjustments.
