HP Pavilion x360 - 14-ba070tu Product Specifications
2JQ93PA
Intel® Core™ i5-7200U (2.5 GHz base frequency, up to 3.1 GHz with Intel® Turbo Boost Technology, 3 MB cache, 2 cores)
8 GB DDR4-2133 SDRAM (1 x 8 GB)
Video graphics
Intel® HD Graphics 620
  • 500 GB 5400 rpm SATA
  • 128 GB M.2 SSD
14" diagonal HD SVA WLED-backlit multitouch-enabled edge-to-edge glass (1366 x 768)
Keyboard
Full-size island-style backlit keyboard
Pointing device
802.11a/b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 combo
1 HDMI; 1 headphone/microphone combo; 1 USB 3.1 Type-C™ Gen 1 (Data up to 5 Gb/s); 2 USB 3.1 Gen 1 (Data transfer only)
Dimensions (W x D x H)
33.48 x 22.69 x 2.07 cm
Starting at 1.63 kg
45 W AC power adapter
3-cell, 41 Wh Li-ion
HP 3D DriveGuard; HP ePrint; HP Recovery Manager; HP Support Assistant; HP Audio Switch; HP Sure Connect; HP JumpStart; HP Orbit; HP Documentation
