HP Pavilion x360 - 15-br044cl Product Specifications
2DS99UA
Intel® Core™ i7-7500U (2.7 GHz base frequency, up to 3.5 GHz with Intel® Turbo Boost Technology, 4 MB cache, 2 cores)
8 GB DDR4-2133 SDRAM (1 x 8 GB)
Video graphics
  • AMD Radeon™ 530 Graphics (4 GB DDR3 dedicated)
  • Discrete
1 TB 5400 rpm SATA
15.6" diagonal FHD IPS WLED-backlit multitouch-enabled edge-to-edge glass (1920 x 1080)
Keyboard
Pointing device
Intel® 802.11b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo
1 USB 3.1 Type-C™ Gen 1 (Data Transfer up to 5 Gb/s, Power Delivery, DP1.2, HP Sleep and Charge); 2 USB 3.1 Gen 1 (Data transfer only); 1 HDMI; 1 headphone/microphone combo
37.78 x 24.58 x 2.13 cm
2.14 kg
65 W AC power adapter
3-cell, 48 Wh Li-ion
B&O PLAY, dual speakers
HP Orbit; HP 3D DriveGuard; HP CoolSense; HP ePrint; HP Games by WildTangent; HP Audio Switch; HP Jumpstart; HP Recovery Manager; HP Support Assistant
Pre-installed software
Netflix
