HP Desktop PCs - Motherboard Specifications, Java-U
Figure : Java-U motherboard top view
Figure : Java-U motherboard bottom view
Motherboard description
HP name: Java-U
SSID: 8381
Form factor
Customized: 15.0x14.0 cm (5.9x5.5 in)
The chipset on this motherboard is combined with the processor into a single integrated circuit called System on a Chip (SoC). This technology combines the processor and chipset functionality into a single physical package.
Processor upgrade information
Supports the AMD A9-9400 (Stoney Ridge), the AMD A6-9200 (Stoney Ridge), the AMD A4-9120 (Stoney Ridge), AMD A4-9125 (Stoney Ridge), and the AMD E2-9000 (Stoney Ridge) Dual Core processors only. The processor that is shipped with your model is soldered and is not upgradeable.
Memory upgrade information
Single channel memory architecture
One DDR4 SODIMM (260-pin) socket
Supports the following:
PC4-17000 (DDR4-2133)
PC4-19200 (DDR4-2400)
Supports 2 GB, 4 GB, and 8 GB DDR4 SODIMMs
Supports up to 4 GB on 32-bit systems
32-bit systems cannot address a full 4.0 GB of memory.
Supports up to 8 GB on 64-bit systems
Maximum memory shown reflects the capability of the hardware and can be limited further in the operating system.
Some features of the tool may not be available at this time. We apologize for this inconvenience and are addressing the issue.Minimize Chat bot windowLoading ChatbotNew Message
