HP ZBook 14u G4 Mobile Workstation - Specifications
Feature
Preinstalled
Windows 10 Home Single Language 641
Windows 10 Pro 641
FreeDOS 1.2
Supported
Windows 10 Enterprise 641
1Not all features are available in all editions or versions of Windows. Systems might require upgraded and/or separately purchased hardware, drivers, software, or BIOS update to take full advantage of Windows functionality. Windows 10 automatic updates are always enabled. ISP fees might apply and additional requirements might apply over time for updates.
In accordance with Microsoft support policy, this product does not support Windows 8 or Windows 7. HP does not support the Windows 8 or Windows 7 operating system on products configured with Intel and AMD 7th generation or later processors, or provide any Windows 8 or Windows 7 drivers.
Processors
Intel Core i7 7600U
2.8 GHz
4 MB cache, 2 cores
Up to 3.9 GHz with Intel Turbo Boost Technology
Intel Core i7 7500U
2.7 GHz
4 MB cache, 2 cores
Up to 3.5 GHz with Intel Turbo Boost Technology
Intel Core i5 7300U
2.6 GHz
3 MB cache, 2 cores
Intel Core i5 7200U
2.5 GHz
3 MB cache, 2 cores
Up to 3.1 GHz with Intel Turbo Boost Technology
Intel Core i5/Core i7 with vPro technology capable (optional)
Intel Virtualization Technology (Intel VT)
Intel Active Management Technology (iAMT)
For Windows operating system only.
Future virtual appliances applications dependent on third-party software and compatibility to be determined.
Integrated with processor
Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. Performance and clock frequency vary depending on application workload and hardware and software configurations. Intel numbering is not a measurement of higher performance.
Intel Turbo Boost is based on maximum GHz for a single core.
Graphics
Feature
Integrated
Intel HD Graphics 620
High-definition (HD) content is required to view high definition images.
Discrete
AMD FirePro W4190M (2 GB dedicated GDDR5)
Supports up to 3 independent displays via internal LCD Panel, system DisplayPort, system VGA, or using the HP UltraSlim Docking Station DisplayPort and VGA ports (sold separately).
Supports AMD Enduro Technology
Microsoft DirectX 12 (Shader Model 5.0) and OpenGL 4.3 capable
Displays
Feature
Internal
35.56 cm (14.0 in) diagonal LED backlit FHD SVA eDP anti-glare (1920 x 1080)
35.56 cm (14.0 in) diagonal LED backlit FHD UWVA IPS eDP anti-glare (1920 x 1080)
35.56 cm (14.0 in) diagonal Touch LED-backlit FHD SVA eDP (1920 x 1080)
35.56 cm (14.0 in) diagonal LED backlit HD SVA eDP (1366 x 768)
External
Up to 30-bit per pixel (2^30) Deep Color (total of 1,073,741,824 color variations)
VGA
Supports resolutions up to 1920 x 1200 at 60 Hz, and lower resolutions up to 75 Hz
DVI-D (single link)
DVI support requires a DP-to-DVI adapter (sold separately)
Dual-Link DVI is supported with an active USB powered adapter (sold separately)
DisplayPort with Multi-stream Transport (MST)
Supports resolution up to UHD 3840 x 2160 and 24/30-bit color depth at 60 Hz
Supports WUXGA (1920 x 1200) monitors, with 24/30-bit color depth up to 120 Hz
Resolutions are dependent upon monitor capability and resolution and color depth settings.
Storage and drives
Feature
SATA 6.35 cm (2.5 in) Hard Drive
1 TB 5400 rpm Hard Drive
500 GB 7200 rpm Hard Drive
500 GB 7200 rpm Self Encrypting Drive (Opal 2)
500 GB 7200 rpm Self Encrypting Drive FIPS 140-2 compliant
500 GB 5400 rpm Hybrid Drive (8 GB cache)
M.2 SATA SED SSD
256 GB SATA-3 Self-Encrypting (Opal 2) TLC Solid State Drive
512 GB SATA-3 SS TLC SSD FIPS-140-2
HP Z Turbo Drive (NVMe PCIe SSD)
256 GB PCIe (NVMe) TLC Solid State Drive
256 GB PCIe (NVMe) MLC Solid State Drive
512 GB PCIe (NVMe) MLC Solid State Drive
1 TB PCIe (NVMe) MLC Solid State Drive
512 GB PCIe (NVMe) TLC Opal 2 Solid State Drive
HP 3D DriveGuard (Windows only)
Mounted directly to the notebook frame
Hard drive controllers
6.35 cm (2.5 in) storage bays and M.2 storage bay (SATA)
SATA-3 for HDD
SATA-3 for SSD
HP Z Turbo Drive
PCIe NVMe SSD
For solid state drives or hard drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 30 GB is reserved for system recovery software.
Memory
Specification
Standard
32 GB DDR4 1.2 V non-ECC SDRAM (transfer rates up to 2133 MT/s)
(2) SODIMM slots supporting dual-channel memory
4 GB, 8 GB, and 16 GB SODIMMs
Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory channels
Maximum
Up to 64 GB
Optional 16 GB SODIMMs in 2 slots
Maximum memory capacities assume Windows 64-bit operating systems or Linux. With Windows 32-bit operating systems, memory above 3 GB might not all be available due to system resource requirements.
Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility. If memory speeds are mixed, the system performs at the lower memory speed.
Ports/slots
Ports
Left side
(1) VGA
(1) USB 3.0 Charging port
(1) Security lock slot
Right side
(1) USB 3.1 Gen 1
(1) USB 3.0
(1) RJ-45/Ethernet
(1) DisplayPort 1.2
(1) Headphone/microphone combo jack
(1) Side docking connector
(1) Power connector
Digital media slots
(1) SD UHS-II Flash media slot
Supports next generation Secure Digital (SD), backward compatible to SDHC and SDXC
(1) Integrated Smart Card reader
Compatible with ISO 7816 compliant Smart Cards PC/SC interface support
Audio/multimedia
Feature
Audio
Audio by Bang and Olufsen
Integrated stereo speakers
Integrated microphone (dual-microphone array when equipped with optional webcam)
Button for volume mute; function keys for volume up and down
Combo microphone-in/stereo headphone-out jack
Camera
720p HD webcam
HD format (widescreen)
Supports videoconferencing and still image capture
High quality fixed focus lens
Video capture at various resolutions up to 1280 x 720 resolution (720p) and up to 30fps
M-JPEG compression supports higher frame rates for video capture and videoconferencing
Improved low light sensitivity
Improved dynamic range
Keyboard/pointing devices/buttons/function keys
Feature
Keyboard
General features
Optional backlit keyboard
Function key control to toggle backlit brightness setting: off/full/half brightness
Spill-resistant with drain (thin layer of Mylar film under the keyboard)
100-key compatible keyboard
U.S. and International key layouts available
Full-pitch key layout
Editing keys
Both left and right control and alt keys
Function keys
18.0 x 18.4 mm key pitch (center-to-center spacing)
Hot keys for instant access to power conservation and brightness
Pointing devices
Touchpad with On/Off button
Two-way scroll
Gestures
(2) pick buttons
Point stick with two additional point stick buttons
Image sensor touchpad for enhanced performance and improved precision on scroll and gesture
Buttons
Wireless on/off
Volume mute
Function keys
Standby mode
External display
Volume down
Volume up
Display brightness
Networking/communication
Feature
Communications1
Integrated Intel I219-LM Gigabit Network Connection (vPro configurations)
Integrated Intel I219-V Gigabit Network Connection (non-vPro configurations)
Broadband Wireless (WWAN)
Requires a Windows operating system (not available in all countries/regions)
Factory configurable only
Integrated Bluetooth
Combined with the supported wireless LAN options
802.11 Wireless LAN2
Intel Dual Band Wireless-AC 8265 802.11a/b/g/n/ac (2x2) WiFi with Bluetooth 4.2 Combo Adapter (vPro)
Intel Dual Band Wireless-AC 8265 802.11a/b/g/n/ac (2x2) WiFi with Bluetooth 4.2 Combo Adapter (non-vPro)
Intel Dual Band Wireless-AC 3168 802.11ac (1x1) WiFi and Bluetooth 4.2 Combo Adapter (non-vPro)
Wireless WAN - Mobile Broadband (optional)3
HP lt4120 Qualcomm Snapdragon X5 LTE Mobile Broadband Module
HP It4132, LTE/HSPA+ 4G Mobile Broadband Module
HP hs3210 HSPA+ Mobile Broadband Module
Near Field Communications (NFC)
HP Module with NXP NFC Controller NPC100
Secure, integrated wireless LAN and wireless WAN options supports the latest industry standards.
1The term 10/100/1000 or Gigabit Ethernet indicates compatibility with IEEE standard 802.3ab for Gigabit Ethernet, and does not connote actual operating speed of 1 Gb/s. For high-speed transmission, connection to a Gigabit Ethernet server and network infrastructure is required.
2Wireless cards are optional or add-on features. Wireless access point and Internet service required and not included. Availability of public wireless access points limited. The specifications for the 802.11ac WLAN are draft specifications and are not final. If the final specifications differ from the draft specifications, it might affect the ability of the workstation to communicate with other 802.11ac WLAN devices.
3WWAN use requires separately purchased service contract. Check with service provider for coverage and availability. Connection speeds varies due to location, environment, network conditions, and other factors. 4G LTE not available on all products, and in all countries/regions.
Software/security
Specification
BIOS
HP BIOSphere Gen3
Requires Intel 7th generation processors.
HP Sure Start Gen3
Available on HP Elite products equipped with Intel 7th generation processors.
BIOS Update via Network
Master Boot Record Security
Power On Authentication
Secure Erase (methods outlined in the National Institute of Standards and Technology Special Publication 800-88)
Absolute Persistence Module1
Pre-boot Authentication
Multimedia
Cyberlink Power MediaPlayer CMIT
Communication/connectivity
HP Mobile Connect Pro
Only available on preconfigured devices with WWAN.
Native Miracast Support
HP LAN-WLAN Protection
HP MAC Address Manager (select models only)
HP Wireless Wakeup (select models only)
HP SureConnect
HP Value Add Software
HP 3D DriveGuard (requires Windows)
HP ePrint Driver with JetAdvantage2
HP Hotkey Support
HP Recovery Manager
HP Jumpstart
HP Support Assistant (requires Windows and internet access)
HP Noise Cancellation Software
HP Performance Advisor
HP Remote Graphics Software
HP Velocity
Microsoft Products
Buy Office
Bing Search
Skype (not available in China)
Manageability
HP Driver packs (available for download)
HP SoftPaq Download Manager (SDM)
HP System Software Manager (SSM) (available for download)
HP BIOS Configuration Utility (BCU) (available for download)
HP Client Catalog (available for download)
HP Management Integration Kit for Microsoft SCCM (available for download)
HP Image Assistant
LANDESK Management (subscription required)
Discover HP Touchpoint Manager3
For more information about manageability software, go to the HP Client Management Solutions webpage.
Client Security software
Microsoft Defender (opt in and internet connection required for updates)
HP WorkWise app (available as a free download on the App Store and Google Play)
HP Client Security Suite Gen3 (requires Windows and Intel 7th generation processors)
HP Security Manager (including Credential Manager and Password Manager)
HP Fingerprint Sensor
Device Access Manager
Security
For Windows 10, Trusted Platform Module (TPM) 2.0 (Infineon SLB9670)
Common Criteria EAL4+ Certified
HP Fingerprint Reader
For more information about security software and features, go to the HP Client Security Software Suite webpage.
Workstation ISV certifications
Go to the Workstation ISV Certifications webpage to see current certifications
HP Remote Graphics software
Available for download from the HP Remote Graphics Software webpage
Enables optimal configuration
Available for download from HP Performance Advisor webpage
Other standard security features
Integrated Smart Card Reader
One-Step Logon
Security lock slot
Support for Intel AT
Optional security features
Absolute Data Protect1
GPS Tracking - Subscription based security solution (requires HP Mobile Broadband Module)
1Absolute agent is activated when customers activate a purchased subscription. Subscriptions can be purchased for terms ranging multiple years. Service is limited, check with Absolute for availability outside the U.S. The Absolute Recovery Guarantee is a limited warranty. Certain conditions apply. Data Delete is an optional service provided by Absolute Software. If utilized, the Recovery Guarantee is null and void. In order to use the Data Delete service, customers must first sign a Pre-Authorization Agreement and either obtain a PIN or purchase one or more RSA SecurID tokens from Absolute Software.
2Requires an Internet connection to HP web-enabled printer and HP ePrint account registration. Requires optional broadband module. Broadband use requires separately purchased service contract. Check with service provider for coverage and availability in your area. Separately purchased data plans or usage fees might apply. Print times and connection speeds might vary.
3HP Touchpoint Manager requires purchase of a subscription and supports Android, iOS and Windows 7 or higher operating systems and PCs, notebooks, tablets and smartphones from various manufacturers. Not available in all countries/regions.
Power
Power supply
HP 65W Slim Smart AC Adapter
Primary battery
HP 3-cell Long Life Polymer Battery (51 WHr)
Battery life
Battery life up to 10 hours
Battery life varies depending on the product model, configuration, loaded applications, features, use, wireless functionality, and power management settings. The maximum capacity of the battery naturally decreases with time and usage. For more information, see MobileMark14 battery benchmarks.
Power conservation
Hibernation
Standby
ACPI compliance
Physical specifications
Dimensions (W x D x H)
33.78 x 23.62 x 2.21 cm (13.3 x 9.3 x 0.87 in)
Height varies depending upon where on the workstation the measurement is made.
1.64 kg (3.61 lb)
Weight varies by configuration and components. Weight includes 3-cell 46 Whr battery, without hard drive and with 256 GB Z Turbo Drive (PCIe SSD).
Environmental
Feature
Certifications
US ENERGY STAR (select models only)
Configurations of the HP ZBook 14u G3 that are ENERGY STAR certified are identified as HP HP ZBook 14u G3 ENERGY STAR on HP websites.
Low Halogen
External power supplies, power cords, cables and peripherals are not low halogen. Service parts obtained after purchase might not be low halogen.
IT ECO declaration
EPEAT Gold registered where applicable (registration varies by country/region)
This product has received or is in the process of being certified to the the approvals and might be labeled with one or more of these marks.
Planned industry standard certifications
UL
CSA
FCC compliance
ICES
Australia/NZ A-Tick compliance
CCC
Japan VCCI compliance
KC
BSMI
CE marking compliance
MIL STD
Stand-alone power requirements (AC power)
Nominal operating voltage
19.5 V DC at 3.3 A
Average operating power (Windows 10 64-bit)
AMD FirePro graphics
Maximum operating power
< 65 W
Temperature
Operating
0° to 35° C (32° to 95° F) (not writing optical)
5° to 35° C (41° to 95° F) (writing optical)
Non-operating
-20° to 60° C (-4° to 140° F)
Relative humidity
Operating
10% to 90%, non-condensing
Non-operating
5% to 95%, 38.7° C (101.6° F) maximum wet bulb temperature
Shock
Operating
40 G, 2 ms, half-sine
Non-operating
200 G, 2 ms, half-sine
Random vibration
Operating
0.75 grms
Non-operating
1.50 grms
Altitude (unpressurized)
Operating
-15.24 to 3,048 m (-50 to 10,000 ft)
Non-operating
-15.24 to 12,192 m (-50 to 15,000 ft)
