Remove and Replace the System Memory on the HP OMEN 880 Gaming PC
This document applies to HP OMEN 880 Gaming PCs.
Before you begin
  • Have available a Phillips-head screwdriver.
  • Turn off the computer. Disconnect the Ethernet or modem cable. Disconnect the power cord.
  warning:
Make sure the computer is disconnected from power before starting. Before starting, power off the computer and wait for components to cool before starting these procedures.
Procedures in this document are provided by HP for qualified service agents and as a courtesy to its customers. Servicing internal components increases the risk of damaging the computer which might not be covered under warranty. Understand the risk and refer to the product's warranty before attempting to service the computer.
Video overview
Removing the system memory
To remove the system memory, use the following instructions:
Step 1
Remove the left side cover.
Removing the left side cover
Step 2
Find the top retaining clip of the memory socket.
Top retaining clip of the memory socket
Step 3
Press down on the top retaining clip of the memory socket.
Pressing down on the retaining clip
Step 4
Angle the top part of the memory module out of its socket and pull the bottom part of the module firmly out of the socket.
The motherboards for this unit have a special memory socket design that requires only one retaining clip to be pushed to remove the module from the socket. The clip on the bottom side of the socket is not maneuverable.
Angling the top part of the memory module out of its socket
Replacing the system memory
Use the following instructions to replace the system memory:
Step 1
Find the notch on the bottom of the memory module that is offset from the center and fits over the...
... tab in the motherboard memory socket...
Notch on the bottom of the memory module
Tab in the motherboard memory socket
...and now, find the notch cut into the side of each memory module...
...that fits over a small tab on the inside edge of the bottom memory retention clip.
Notch in the side of the memory socket
 Tab on the inside edge of the bottom memory retention clip
Step 2
To replace a memory module in this unit, press the bottom side notch of the memory module over the tab on the bottom clip.
Placing the notch on the memory module over the tab on the clip and lowering it into place
Step 3
Press the top part of the memory module firmly into the socket until the top retaining clip snaps into place at the top side of the module.
Pressing the module down and the clip snaps into place
Step 4
Replace the left side cover.
Replacing the left side cover
