Samsung Laser Printers - How to Scan with the Samsung MobilePrint App
Before You Start
This app will only Scan with specific Samsung printers. See the app description in the Play Store or App Store for the up-to-date list of supported printers.
You can scan directly to your smartphone using the Samsung MobilePrint App.
Before starting, make sure of the following:
  • The Samsung MobilePrint App has been installed on your smartphone.
  • Your smartphone is connected to the same Wi-Fi network as your printer, or is connected to the printer though Wi-Fi direct.
  • Your printer has already been selected on the Samsung MobilePrint App.
To Scan Using Samsung MobilePrint
  1. Tap the Samsung MobilePrint App to open.
  2. Tap Scan at the top of the screen.
    If a printer has not already been selected and connected to, Samsung MobilePrint App will prompt you to choose a printer from a list of printers that are currently connected to the same Wi-Fi network as your smartphone. If no printers show in the list, either the printer or the smartphone is not connected to the Wi-Fi network.
  3. On this screen, you can change options for scan settings, such as Paper Size, Color/Grayscale, Image Resolution, FlatBed/ADF (Automatic Document Feeder, for printer models that have one), and File Format (JPEG, PNG, or PDF).
  4. Tap Preview to see what the scan will look like, or Scan to scan. The scanner takes a few seconds to scan your document or picture.
  5. Tap Yes to scan more, or No if finished scanning.
  6. Your scan is completed and will be saved to your smartphone's photo gallery (normally under a folder marked "Scans"). Tapping Send will give different options for sending the scan, such as email, text message, Dropbox, and Google Drive.
Country: Flag Thailand
