HP OfficeJet Pro 7720, 7730 Printers - Control Panel Features
This document is for HP OfficeJet Pro 7720, 7730 Wide Format All-in-One printers.
The control panel includes buttons, icons, and a touchscreen to select print options.
Control panel buttons and lights
From the control panel, access the Home button, verify wireless connectivity, and access Help menus.
Figure : Control panel buttons, icons, and lights
Example of the control panel buttons, icons, and lights
1. Home button: Returns the control panel to the Home screen.
2. Touchscreen display: Touch the screen to select menu options, or swipe your finger across the display to scroll through the menu items.
3. Wireless status light: Indicates the status of the printer wireless connection. A solid blue light indicates that a wireless connection is established and that you can print wirelessly. If the wireless feature is turned off, the wireless light is off and the Wireless Summary screen displays Wireless Off.
4. Back button: Returns to the previous screen.
5. Help button: Opens the Help menu for the current operation.
Control panel menu
Touch the control panel to select fax, copy, scan, and apps options from the main menu. Swipe your finger across the display to scroll through the shortcuts or down the display to open the Dashboard.
Figure : Control panel menu
Example of the control panel display menu
1. Setup: Displays the setup screen to change preferences, network setup, Wi-Fi Direct, fax setup, maintenance settings, and print reports.
2./ Wireless/Ethernet icon: The Wireless icon opens the Wireless Summary menu to check wireless status and change wireless settings. You can print a wireless test report to help diagnose network connection issues. If there is no network connection, the Wireless icon displays by default.
3. HP ePrint icon: Opens the Web Services Summary menu to check ePrint status details, change ePrint settings, or print a Web Services Information page.
4. Wi-Fi Direct icon: Opens the Wi-Fi Direct menu to turn on or off Wi-Fi Direct printing and display the Wi-Fi Direct name and password.
5. Ink icon: Displays estimated ink levels by ink cartridge. The icon displays a warning symbol if the ink level is less than the minimum expected ink level.
6. Fax status icon: Opens status information for the Auto Answer function, fax logs, and the fax sound volume.
7. Eco icon: Opens the Eco menu where you can configure some of the printer's environmental features.
8. Copy shortcut: Displays options to copy documents, photos, or IDs, and change copy settings.
9.Scan shortcut: Displays options to scan to a computer or email.
10.Fax shortcut: Displays options to quickly send a fax or change fax settings.
11.Apps shortcut: Displays downloaded print apps.
