Figure : HP N246v 23.8-inch Monitor
Specification
Dimensions
(W × D × H)
Unpacked with stand
54.66 x 20.98 x 40.51 cm
(21.52 x 8.26 x 15.95 in)
Packaged
60.71 x 12.50 x 40.49 cm
(23.90 x 4.92 x 15.94 in)
Unpacked without stand (head only)
54.66 x 4.47 x 32.10 cm
(21.52 x 1.76 x 12.64 in)
Unpacked with stand
3.65 kg (8.05 lb)
Packaged
4.75 kg (10.47 lb)
Head only
3.30 kg (7.27 lb)
Specification
Type
23.8-inch, IPS
Viewable image area
(diagonal)
60.45 cm (23.8 in) widescreen
Panel active area (W x H)
52.68 x 29.64 cm (20.74 x 11.67 in)
Resolution
1920 x 1080 at 60 Hz
Aspect ratio
16:9
Viewing angle (typical)
Up to 178° horizontal
Up to 178° vertical
Brightness (typical)
250 cd/m2
Contrast ratio (typical)
700:1 static (minimum)
1000:1 static (typical)
Dynamic contrast ratio (typical)
10,000,000:1 dynamic (DCR)
Response times (typical)
5 ms (with overdrive)
Pixel pitch
0.275 x 0.275 mm
Pixels Per Inch (PPI)
93
Default color temperature
6500 K
Backlight lamp life
30,000 hours minimum (to half brightness)
Panel bit depth
8-bit
Color gamut (typical)
72% (NTSC)
Anti-glare panel
Yes
note:Actual performance varies.
Specification
Buttons or switches
Menu, Minus ("-"), Plus ("+") /Input Control, and Power
User Programmable Modes
Yes, 3 (6 options)
Languages
10 (English, Spanish, German, French, Italian, Dutch, Portuguese, Japanese, Simplified Chinese, and Traditional Chinese)
On-screen Display
(OSD)
user controls
Brightness, Contrast, Color Control, Input Control,
Image Control, Power Control, Menu Control, Management, Language, Information, and Exit
Specification
Native resolution
Preset graphic modes (non-interlaced)
640 x 480 at 60 Hz
720 x 400 at 70 Hz
800 x 600 at 60 Hz
1024 x 768 at 60 Hz
1280 x 720 at 60 Hz
1280 x 800 at 60 Hz
1280 x 1024 at 60 Hz
1440 x 900 at 60 Hz
1600 x 900 at 60 Hz
1680 x 1050 at 60 Hz
Pixel clock
170 MHz
Vertical frequency
50 - 60 Hz
Horizontal frequency
30 - 80 kHz
Specification
Plug and play
Yes
Input connectors
(1) VGA
(1) DVI
(1) HDMI (HDCP support)
Video cables included
(1) VGA cable 1.5 m (4.9 ft)
Specification
Color
Black
Detachable stand
Yes, ships detached
Tilt range
-5° to + 20° vertical
VESA mounting
Yes, 100 mm
Security lock-ready
Yes
note:Not available on head only model.
Specification
Power supply
Internal
Input power
100 - 240 VAC 50/60 Hz
Maximum power
25 W
Typical power
22 W
Power saving
0.5 W
Power cable length
1.9 m (6.23 ft)
Specification
Monitor and accessories
AC power cord, 1.9 m (6.23 ft)
VGA cable, 1.5 m (4.92 ft)
Documentation
CD (includes User guide, warranty, and drivers)
Specification
Dimensions
(W × D × H)
Unpacked with stand
Packaged
Unpacked with stand
3.65 kg (8.05 lb)
Packaged
4.75 kg (10.47 lb)
Head only
3.30 kg (7.27 lb)
Specification
Temperature
Operating
5° to 35° C (41° to 95° F)
Non-operating
-20° to 60° C (-4° to 140° F)
Humidity
Operating
20% to 80% non-condensing
Non-operating
5% to 95%
Altitude
Operating
0 to 5,000 m (0 to 16,400 ft)
Non-operating
0 to 12,192 m (0 to 40,000 ft)
Arsenic-free display glass
Yes
Mercury-free display backlighting
Yes
White LED backlights
Yes
Eco-label certifications & declarations
CB
TUV low blue light
CCC
CEL
CECP
SEPA
WEEE
