    Fix Windows 10 Update Issues
HP PageWide Pro 750, MFP 772, 777 - Load the document feeder
The document feeder holds up to 100 sheets of 75 g/m2 paper.
When using the document feeder, make sure that your documents contain no staples, paper clips, tape, or similar items that can damage the product.
  1. Open the document feeder paper guides.
  2. For longer documents, pull the document feeder loading area extension outward if necessary.
  3. Notice the media mark on the tray, which shows the correct orientation for paper.
    Place the documents to be copied in the document feeder loading area face up.
  4. Push the documents to the left until they are stopped by the feeder mechanism under the document feeder cover. A Document Loaded message appears on the printer control panel.
  5. Close the paper guides securely against the loaded documents.
