HP PageWide Pro 750, MFP 772, 777 - Install HP printer software for a wireless product already on the network
If the product already has an IP address on a wireless network and you want to install product software on a computer, complete the following steps:
  1. Obtain the product IP (on the control panel dashboard, touch [Ethernet]).
  2. Install the printer software from www.support.hp.com.
  3. Follow the onscreen instructions.
  4. When prompted, select Wireless - Connect the printer to your wireless network and internet, and then click Next.
  5. From the list of available printers, select the printer that has the correct IP address.
