HP PageWide Pro 750, MFP 772, 777 - Product views
Front left view
Figure : MFP 772, 777
Label
1
Left door
2
Host USB Type A port
3
Scanner glass
4
Control panel (the following sizes depend on model):
  • 203-mm (8-in) (shown)
  • 109-mm (4.3-in)
5
Release button for 203-mm (8-in) control panel - press to raise the control panel
6
Lower trays (available as optional accessories only):
Lower trays (available as a standard feature or as an optional accessory):
  • 550-sheet tray
  • 550-sheet tray and stand
  • 3x550-sheet tray and stand (shown)
  • 4000-sheet high-capacity input trays and stand
7
Depending on model, the product may have one of the following:
  • Tray 2 (single), right graphic: This is the default tray for the product
  • Trays 2 and 3 (tandem), left graphic: Tray 3 is the default tray for the product
8
Power button
9
Stapler/stacker (available on select models)
10
Cartridge door
11
Left duplexer
Figure : 750
Label
1
Left door
2
3
Control panel
4
Power button
5
  • 550-sheet tray
6
Tray 2 - This is the default tray for the product
7
Cartridge door
8
Left duplexer
Front right view
Label
1
Document feeder cover
2
Document feeder output bin
3
Document feeder paper guides
4
Document feeder loading area
5
Document feeder output bin stop
6
Lower right door (available with optional accessories only)
Lower right door (available in some models only)
7
Right door
8
Right duplexer
9
Output bin
Figure : 750
Label
1
Output bin
2
Right door
3
4
Right duplexer
Back view
Label
1
Stapler door (available on select models)
2
Tray 1 extension
3
Tray 1 (multipurpose tray)
4
Fax connection ports
5
Ethernet connection port
6
Host USB Type A port and Device USB Type B port
7
Power cord connection
Figure : 750
Label
1
2
3
4
5
Tray 1 extension
Cartridge and product numbers
Label
1
Cartridge slots
2
Cartridge part numbers
3
Product serial number and product number
