    Looking for Site Help?
HP Color LaserJet Enterprise MFP M681, M682 printers - Printer views
Printer front view
Figure : Printer front view
  1. Document-feeder cover (access for clearing jams)
  2. Document-feeder input tray
  3. Document-feeder output binWhen feeding long paper through the document feeder, extend the paper stop at the right side of the output bin.
  4. Control panel with color touchscreen display (tilts up for easier viewing)
  5. Right door (access to the fuser and for clearing jams)
  6. Tray 1
  7. On/off button
  8. Tray 2
  9. Model name
  10. Front door (access to the toner cartridges)
  11. Standard output bin
  12. Physical keyboard (Flow models only). Pull the keyboard straight out to use it.Close the keyboard when it is not in use.
  13. Easy-access USB port (on the side of the control panel)Insert a USB flash drive for printing or scanning without a computer or to update the printer firmware.An administrator must enable this port before use.
  14. Hardware integration pocket (for connecting accessory and third-party devices)
  15. 1x550-sheet paper feeder with stand
  16. Lower-right door (access for clearing jams)
  17. Stapler-cartridge door (z models only)
  18. Stapler/stacker-right door (z models only)(access for clearing jams)
  19. 3 x 550-sheet paper feeder with stand
  20. 3-bin stapler/stacker
  21. High-capacity paper feeder and 550-sheet paper feeder with stand
Printer back view
    Figure : Printer rear view
  1. Formatter cover
  2. Formatter (contains the interface ports)
  3. Left door (access to the toner-collection unit)
  4. Power connection
  5. Slot for a cable-type security lock
  6. Serial number and product number label
Interface ports
    Figure : Interface ports
  1. Fax port (f and z models only. The port is covered for the dh models.)
  2. Local area network (LAN) Ethernet 10/100/1000 Ethernet network port
  3. Hi-Speed USB 2.0 printing port
  4. USB port for connecting external USB devices (this port might be covered)For easy-access USB printing, use the USB port near the control panel.
Control-panel view
The Home screen provides access to the printer features and indicates the current status of the printer.
Return to the Home screen at any time by touching the Home button on the left side of the printer control panel, or touch the Home button in the upper-left corner of most screens.
For more information about the printer-control-panel features, go to www.hp.com/support/colorljM681MFP or www.hp.com/support/colorljM682MFP Select Manuals, and then select General reference.
The features that appear on the Home screen can vary, depending on the printer configuration.
    Figure : Printer control panel
  1. Home button
  2. Applications area
  3. Reset button
  4. Sign In or Sign Out button
  5. Information button
  6. Help button
  7. Current time
  8. Start Copy button
  9. Copy count
  10. Home-screen page indicator
  11. Keyboard(Flow models only)
  12. Easy-access USB port
  13. Hardware integration pocket (HIP)
How to use the touchscreen control panel
Use the following actions to use the printer touchscreen control panel.
Action
Example
Touch
Touch an item on the screen to select that item or open that menu. Also, when scrolling through menus, briefly touch the screen to stop the scrolling.
Touch the Settings icon to open the Settings app.
Swipe
Touch the screen and then move your finger horizontally to scroll the screen sideways.
Swipe until the Settings app displays.
Scroll
Touch the screen and then move your finger vertically to scroll the screen up and down. When scrolling through menus, briefly touch the screen to stop the scrolling.
Scroll through the Settings app.
Country: Flag Thailand
