HP OfficeJet Pro 7720 Printers - First Time Printer Setup
This document is for HP OfficeJet Pro 7720 Wide Format All-in-One printers.
To set up a printer for the first time, remove the printer and all packing materials from the box, connect the power cable, set control panel preferences, install the ink cartridges, load paper into the input tray, and then download and install the printer software.
If you are looking for the printer software, go to 123.hp.com/OJP7720 to download the print driver.
Take the printer out of the box, and then remove all tape, stickers, and packing materials from the printer.
  1. Take the printer out of the box.
  2. Remove all tape and packing materials from the outside of the printer.
    Figure : Removing tape from the printer
  3. Lift the scanner lid, remove the packing material from the scanner glass, and then close the scanner lid.
    Figure : Opening the scanner lid and removing packing material
     Removing material from the scanner
  4. Recycle the packing materials.
Step 2: Connect the power cord and set your preferences
Plug the printer into a wall outlet, turn on the printer, and then set your preferences.
    Figure : Connecting the power cord
  2. Turn on the printer.
  3. To set your preferences on the printer control panel, touch your preferred language and country/region, and then touch Yes to confirm your choices.
  4. Select the date and time, and then touch Yes to confirm.
Install the HP Setup ink cartridges that came in the box with your printer.
You must install the Setup ink cartridges when first setting up the printer, or an ink cartridge error occurs.
  1. Open the ink cartridge access door.
    Figure : Opening the ink cartridge access door
  2. Wait until the carriage is idle and silent before you continue.
  3. Remove the plastic wrappers on the ink cartridges. Be careful to touch only the black plastic on the ink cartridge.
  4. Hold the ink cartridge by its sides with the color circle toward you, and then press the ink cartridge forward into its slot until it snaps into place.
    Figure : Inserting the ink cartridge
    Reinserting the ink cartridge
  5. Install the other ink cartridges.
  6. Close the ink cartridge access door.
    Figure : Closing the ink cartridge access door
Remove packing materials from the paper tray, and then load plain U.S. letter or A4 paper.
  1. Pull out the input tray, and then remove the packing materials.
    Figure : Opening the input tray, and then removing the packing material
    Pulling out the input tray and removing packing material
  2. Load plain white paper with the short edge forward and the print side down.
    Do not load more paper than indicated on the paper fill guide, or paper jams might occur.
    Figure : Paper fill guide in the paper tray
    Paper fill guide in the input tray
  3. Push the stack into the tray until it stops.
  4. Slide the paper guides in until they rest against the edges of the paper, if necessary.
    Figure : Sliding in the paper width guides
  5. Close the tray extender cover, insert the input tray into the printer, and then pull out the output tray extension.
    The printer aligns the printhead, and then an alignment page automatically prints.
    Figure : Inserting Tray 1 and pulling out the output tray extension
    Reinserting the input tray
  6. Recycle all packing materials.
Your HP printer hardware is now set up, and you can install the printing software.
Step 5: Install the printer software
Download the latest version of the printing software from 123.hp.com/OJP7720, and then follow the on-screen instructions to install the software.
