    We are upgrading our website
Document ID: c05444071
Version: 1
HP EliteBook Folio G1 Notebook PCs - USB-C Port B Does Not Function After Initial Computer Setup
Release date : 24-Mar-2017
Last updated : 01-Aug-2017
DESCRIPTION
USB-C Port B does not function after the initial computer setup. The port does not charge or recognize any USB devices. Port A functions normally.
Figure : USB-C port locations:
SCOPE
The information in this document applies to the following:
Computers:
RESOLUTION
To recover from this issue, perform a G3 reset by pressing the Power button and holding it for 15 seconds, which simulates battery removal. Physically disconnecting the battery from the computer also resolves the issue.
Hardware platforms affected : HP EliteBook Folio G1 Notebook PC
Support Communication Cross Reference ID : IA05444071
