    Fix HP Printer issue on macOS
HP Color LaserJet Managed MFP E77822-E77830, E78323-E78330 - Supported paper sizes and types
Use the following information to check paper sizes and types that are compatible with your printer.
To obtain the best results, select the correct paper size and type in the print driver before printing.
The paper sizes in the following table are supported by your printer. Each paper size is followed by the specific trays and other printer components that are compatible with that paper size.
Paper size
Compatible trays/components
Letter: 215.9 x 279.4 mm
Tray 1, Tray 2, Tray 3, Automatic duplex, Dual-cassette (optional accessory), High-capacity feeder (optional accessory)
Letter Rotated: 279.4 x 215.9 mm
Legal: 215.9 x 355.6 mm
Executive: 184.2 x 266.7 mm
Statement: 139.7 x 215.9 mm
Oficio (8.5 x 13): 215.9 x 330.2 mm
Tabloid: 279.4 x 431.8 mm
Tray 1, Tray 3, Automatic duplex, Dual-cassette (optional accessory)
4 x 6: 101.6 x 152.4 mm
Tray 1
5 x 7: 127 x 177.8 mm
Tray 1
5 x 8: 127 x 203.2 mm
Tray 1
A3: 297 x 420 mm
A4: 210 x 297 mm
A4 Rotated: 297 x 210 mm
A5: 148 x 210 mm
A5 Rotated: 210 x 148 mm
Tray 1
A6: 105 x 148 mm
Tray 1
RA4: 215 x 305 mm
SRA4: 225 x 320 mm
B4 (JIS): 257 x 364 mm
B5 (JIS): 182 x 257 mm
Tray 1
B6 (JIS): 128 x 182 mm
Tray 1
Oficio (216 x 340): 216 x 340 mm
8K: 260 x 368 mm
8K: 270 x 390 mm
8K: 273 x 394 mm
16K: 184 x 260 mm
16K: 195 x 270 mm
16K: 197 x 273 mm
Japanese Postcard: 100 x 148 mm
Tray 1
Double Japanese Postcard: 148 x 200 mm
Tray 1
Envelope #9: 98.4 x 225.4 mm
Tray 1
Envelope #10: 105 x 241 mm
Tray 1
Envelope Monarch: 98.4 x 190.5 mm
Tray 1
Envelope B5: 176 x 250 mm
Tray 1
Envelope C5: 162 x 229 mm
Tray 1
Envelope C6: 114 x 162 mm
Tray 1
Envelope DL: 110 x 220 mm
Tray 1
Custom: 98 x 148 mm to 297 x 432 mm
Tray 1
Custom: 139 x 210 mm to 297 x 364 mm
Tray 2
Custom: 139 x 210 mm to 297 x 432 mm
Tray 3, Dual-cassette (optional accessory)
Custom: 139.7 x 182 mm to 297 x 432 mm
Automatic duplex
Supported paper types
The following paper types are compatible with your printer:
The paper types listed here are supported by all trays and additional printer components unless otherwise noted.
  • Plain
  • HP EcoFFICIENT
  • HP Matte 90 g
  • Light 60-74 g
  • Bond
  • Recycled
  • HP Matte 105 g
  • HP Matte 120 g
  • HP Soft Gloss 120 g
  • HP Glossy 120 g
  • Mid-Weight 96-110 g
  • Heavy 111-130 g
  • Mid-Weight Glossy 96-110 g
  • Heavy Glossy 111-130 g
  • HP Matte 150 g
  • HP Glossy 150 g
  • Extra Heavy 131-175 g
  • Extra Heavy Glossy 131-175 g
  • HP Matte 200 g (Not supported by Tray 1 or Automatic duplex)
  • Cardstock 176-220 g (Not supported by Tray 1 or Automatic duplex)
  • Labels (Supported by Tray 1 only)
  • Letterhead
  • Envelope (Supported by Tray 1 only)
  • Preprinted
  • Prepunched
  • Colored
  • USER TYPE (1-N)
