    Fix HP Printer issue on macOS
Document ID: c05443033
Version: 1
HP April 2017 BIOS Refresh
Release date : 23-Mar-2017
Last updated : 23-Mar-2017
รายละเอียดการเปลี่ยนแปลง
Common changes for all platforms:
  • Fixed issue where rollback PPI does not pop out after change language to non-English from F10 setup menu
  • Fixed issue where SecureBoot status display on Windows does not align with F10 setup menu
  • Fixed issue where system does not boot with USB Accu-Chek Smartpix connected
  • Fixed issue where system boot time longer than 4 minutes when Joystick is connected
  • Fixed issue where legacy boot order will be changed when remove SATA HDD from system
  • Fixed issue where cannot change boot order by BIOSConfigurationUtility
  • Fixed issue where POST cannot prompt the virtual keyboard for user
  • Add Linux repsetup utility support on Intel platform
  • Add Linux Flash utility support on Intel platform
  • Add “NumLock on at Boot” item in F10 setup menu
  • Change instances of "DXE Update" to "BIOS Update"
  • Fixed issue where cannot PXE Boot when CD-ROM Boot is disabled in BIOS
  • Add ability to create a POST Power-On Password when Administrator Password is unknown
  • Fixed issue where PXE not working in UEFI mode
  • Fixed issue where system stop at black screen when unit boot to legacy SATA ODD
  • Allow F1 information can be launch when BIOS power on password is set
  • Fixed issue where system with NVIDIA NVS 310 graphics card continuously reboots without monitor connected
  • Fixed issue where system hangs when the HP S230tm external touch display is connected via USB
  • Fixed issue where USB optical drive is not working properly together with additional USB Devices
  • Fixed issue that Bitlocker recovery key screen cannot be launched when user forgets PIN and press ESC to enter the Bitlocker recovery key
  • Add an option in F10 setup menu to suppress user confirmation prompting
  • Fixed issue where UEFI Boot does not boot from SSD/HDD after USB key initiated MDT
  • Fixed issue where system boot slow with Alcatel-Lucent Keyboard connected on Intel platforms
HP Elite Slice System BIOS 02.05 has the following enhancements added:
  • Update Intel RC code to 2.1.0; MCU to 0x9E
  • Improve usable memory higher than 3GB for system installed with 4GB or higher memory on 32bit OS
  • Fixed issue where USB-C power is reduced in surge mode and disable the rear USB-C power in agency mode
  • Add ADATA AO1P24HC8T1-BQXS 8GB memory support
  • Fixed issue where BIOSConfigurationUtility shows AMT enabled on non-vPro/AMT CPU
  • Fixed issue where system hangs during restart test on Device Guard enabled system
  • Fixed issue where system pop ME error message after provision ME and enable "Power On from Keyboard Ports" function
  • Fixed issue where system hangs when a Phillips Digital Pocket Memo 9620 recorder is connected via USB
HP EliteDesk 800 G2 TWR/SFF System BIOS 02.18 has the following enhancements added:
  • Add enable/disable external ports in F10 setup menu separately
  • Add CPU and Audio information in Advanced System information tab
HP ProDesk 600 G2 MT/SFF System BIOS 02.18 has the following enhancements added:
HP ProDesk 400/480 G3 MT/SFF System BIOS 02.10 has the following enhancements added:
HP ProDesk 490 G3 MT System BIOS 02.11 has the following enhancements added:
HP EliteOne 800 G2 All-in-One System BIOS 02.19 has the following enhancements added:
  • Add new LGD panel support
HP ProOne 600 G2 All-in-One System BIOS 02.16 has the following enhancements added:
HP ProOne 400 G2 All-in-One System BIOS 02.11 has the following enhancements added:
  • Add new INX panel support
  • Fixed issue where external displays connected to DP will not come back on after restart
HP EliteDesk 800 G3 SFF System BIOS 02.22 has the following enhancements added:
HP ProDesk 600 G2 Desktop Mini System BIOS 02.18 has the following enhancements added:
HP ProDesk 400 G2 Desktop Mini System BIOS 02.11 has the following enhancements added:
  • Fixed issue where PXE boot hangs with ARP error message after getting IP address
HP EliteOne 705 G2 All-in-One System BIOS 02.16 has the following enhancements added:
  • Fixed issue where wireless device is still detected in Windows when it is set to disabled in F10 setup
HP EliteDesk 705 G2 Desktop Mini System BIOS 02.12 has the following enhancements added:
Update AGESA code to 1.0.0.1
HP RP9 G1 Retail System BIOS 02.08 has the following enhancements added:
  • Improved security of UEFI code and variables. HP strongly recommends promptly transitioning to these updated BIOS versions which supersede all previous releases
  • Change M.2 SSD boot priority to be higher than HDD by default
  • Fixes system hang when plug over 8 USB devices in the system
  • Add a "Drivelock password on restart" control option in BIOS setup menu
COMPONENT VERSION
System BIOS:
  • HP Elite Slice System BIOS 02.05
  • HP EliteDesk 800 G2 TWR/SFF System BIOS 02.18
  • HP ProDesk 600 G2 MT/SFF System BIOS 02.18
  • HP ProDesk 400/480 G3 MT/SFF System BIOS 02.10
  • HP ProDesk 490 G3 MT System BIOS 02.11
  • HP EliteOne 800 G2 All-in-One System BIOS 02.19
  • HP ProOne 600 G2 All-in-One System BIOS 02.16
  • HP ProOne 400 G2 All-in-One System BIOS 02.11
  • HP EliteDesk 800 G2 Desktop Mini System BIOS 02.22
  • HP ProDesk 600 G2 Desktop Mini System BIOS 02.18
  • HP ProDesk 400 G2 Desktop Mini System BIOS 02.11
  • HP EliteDesk 705 G2 MT/SFF System BIOS 02.19
  • HP EliteOne 705 G2 All-in-One System BIOS 02.16
  • HP EliteDesk 705 G2 Desktop Mini System BIOS 02.12
  • HP RP9 G1 Retail System BIOS 02.08
REASON FOR CHANGE
Regular quarterly release
IMPACT OF CHANGE
No impact of change
Components affected:
System BIOS
DATE OF CHANGE
Effective date : 21-Apr-2017
Hardware platforms affected : HP Elite Slice, HP EliteDesk 705 G2 Desktop Mini PC, HP EliteDesk 705 G2 Microtower PC, HP EliteDesk 705 G2 Small Form Factor PC, HP EliteDesk 800 35W G2 Desktop Mini PC, HP EliteDesk 800 65W G2 Desktop Mini PC, HP EliteDesk 800 G2 Small Form Factor PC, HP EliteDesk 800 G2 Tower PC, HP EliteDesk 800 G3 Small Form Factor PC, HP EliteOne 705 G2 23-inch Touch All-in-One PC, HP EliteOne 800 G2 21.5-inch All-in-One PC, HP EliteOne 800 G2 23-inch Non-Touch All-in-One PC, HP EliteOne 800 G2 23-inch Touch All-in-One PC, HP ProDesk 400 G2 Microtower PC, HP ProDesk 400 G3 Microtower PC, HP ProDesk 400 G3 Small Form Factor PC, HP ProDesk 480 G3 Microtower PC, HP ProDesk 490 G3 Microtower PC, HP ProDesk 600 G2 Desktop Mini PC, HP ProDesk 600 G2 Microtower PC, HP ProDesk 600 G2 Small Form Factor PC, HP ProOne 400 G2 20-inch Non-Touch All-in-One PC, HP ProOne 400 G2 20-inch Touch All-in-One PC, HP ProOne 600 G2 21.5-inch Non-Touch All-in-One PC, HP ProOne 600 G2 21.5-inch Touch All-in-One PC, HP RP9 G1 Retail System Model 9015, HP RP9 G1 Retail System Model 9018
