HP ENVY - 15-as127tu Product Specifications
1AC56PA
Intel® Core™ i7-7500U (2.7 GHz, up to 3.5 GHz with Intel® Turbo Boost Technology, 4 MB cache, 2 cores)
8 GB DDR4-2133 SDRAM (1 x 8 GB)
Video graphics
Intel® HD Graphics 620
256 GB PCIe® NVMe™ M.2 SSD
15.6" diagonal FHD UWVA eDP BrightView WLED-backlit touch screen (1920 x 1080)
Keyboard
Pointing device
Intel® 802.11ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo (Miracast compatible)
1 HDMI; 1 headphone/microphone combo; 3 USB 3.1 Gen 1 (1 HP Sleep and Charge); 1 USB 3.1 Gen 1 Type-C™
38 x 25.5 x 1.79 cm
2.13 kg
45 W AC power adapter
3-cell, 52 Wh Li-ion
HP Wide Vision HD Camera with dual array digital microphone
Bang & Olufsen; Dual speakers; HP Audio Boost
HP 3D DriveGuard; HP ePrint; HP Recovery Manager; HP Support Assistant; HP Documentation
Pre-installed software
Adobe® Shockwave® Player; CyberLink PowerDirector; Dropbox; TripAdvisor
