HP Pavilion - 15-au145ur Product Specifications
1JM37EA
Intel® Core™ i3-7100U (2.4 GHz, 3 MB cache, 2 cores)
4 GB DDR4-2133 SDRAM (1 x 4 GB)
Video graphics
NVIDIA® GeForce® 940MX (2 GB DDR3 dedicated)
500 GB 5400 rpm SATA
Optical drive
DVD-Writer
39.6 cm (15.6") diagonal FHD IPS UWVA BrightView WLED-backlit (1920 x 1080)
Keyboard
Pointing device
802.11b/g/n (1x1) and Bluetooth® 4.0 combo (Miracast compatible)
1 HDMI; 1 headphone/microphone combo; 1 USB 2.0; 2 USB 3.1; 1 RJ-45
38.3 x 24.3 x 2.25 cm
2.04 kg
65 W AC power adapter
2-cell, 41 Wh Li-ion
HP Wide Vision HD Camera with dual array digital microphone
B&O PLAY; HP Audio Boost; Dual speakers
FreeDOS 2.0
