Specification
Pre-installed (Windows)
Windows 10 Pro 641
Windows 10 Home 641
Windows 10 Home Single Language 641
Windows 7 Professional 64 (available through downgrade rights from Windows 10 Pro)2
Pre-installed (other)
FreeDOS 2.0
note:1Not all features are available in all editions or versions of Windows. Systems might require upgraded and/or separately purchased hardware, drivers, software, or BIOS update to take full advantage of Windows functionality. Windows 10 automatic updates are always enabled. ISP fees might apply and additional requirements might apply over time for updates.2This system is preinstalled with Windows 7 Pro software and also comes with a license and media for Windows 10 Pro software. Only one version of the Windows software can be used at a time. Switching between versions requires you to uninstall one version and install the other version. You must back up all data (files, photos, etc.) before uninstalling and installing operating systems to avoid loss of data.
