HP LaserJet Enterprise MFP, HP PageWide Enterprise MFP - Scan to USB drive
The printer can scan a file and save it on a USB flash drive. Before using this feature, use the HP Embedded Web server to enable and configure it.
Scan to USB drive
You might be required to sign in to the printer to use this feature.
The steps vary according to the type of control panel.
FutureSmart 3
FutureSmart 4
