HP ProDesk 480 G4 Microtower Business PC - Specifications
Processors
Specification
Intel Core i7-7700 processor
65 W
Up to 4.2 GHz maximum Turbo Frequency (3.6 GHz base frequency)
8 MB cache, 4 cores, 8 threads
Intel HD Graphics 630
DDR4 memory up to 2400 MT/s data rate
Intel Core i7-6700 processor
65 W
Up to 4.0 GHz maximum Turbo Frequency (3.4 GHz base frequency)
Intel HD Graphics 530
DDR4 memory up to 2133 MT/s data rate
Intel Core i5-7600 processor
65 W
Up to 4.1 GHz maximum Turbo Frequency (3.5 GHz base frequency)
6 MB cache, 4 cores, 4 threads
Intel Core i5-7500 processor
65 W
Up to 3.8 GHz maximum Turbo Frequency (3.4 GHz base frequency)
Intel Core i5-6500 processor
65 W
Up to 3.6 GHz maximum Turbo Frequency (3.2 GHz base frequency)
Intel Core i3-7320 processor
51 W
4.1 GHz base frequency
4 MB cache, 2 cores, 4 threads
Intel Core i3-7300 processor
51 W
4.0 GHz base frequency
Intel Core i3-7100 processor
51 W
3.9 GHz base frequency
3 MB cache, 2 cores, 4 threads
Intel Core i3-6100 processor
51 W
3.7 GHz base frequency
Intel Pentium G4560 processor
54 W
Intel HD Graphics 610
Intel Pentium G4600 processor
51 W
Intel Pentium G4620 processor
51 W
Intel Pentium G4500 processor
51 W
3 MB cache, 2 cores, 2 threads
Intel Pentium G4400 processor
54 W
3.3 GHz base frequency
Intel HD Graphics 510
Intel Celeron G3930 processor
51 W
2.9 GHz base frequency
2 MB cache, 2 cores, 2 threads
Intel Celeron G3950 processor
51 W
3.0 GHz base frequency
Intel Celeron G3900 processor
51 W
2.8 GHz base frequency
Intel H270
In accordance with Microsoft support policy, HP does not support the Windows 8 or Windows 7 operating system on products configured with Intel and AMD 7th generation or later processors, or provide any Windows 8 or Windows 7 drivers.
Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. 64-bit computing system required. Performance and clock frequency vary depending on application workload and hardware and software configurations. Intel numbering is not a measurement of higher performance.
Operating systems
Specification
Pre-installed (Windows)
Windows 10 Pro 641
Windows 10 Pro 64 (National Academic License)3
Windows 10 Home 641
Windows 10 Home Single Language 641
Windows 7 Professional 64 (available through downgrade rights from Windows 10 Pro)2,4
Windows 7 Professional 32 (available through downgrade rights from Windows 10 Pro)2,4
Pre-installed (other)
FreeDOS 2.0
NeoKylin Linux 64
Web-supported
Windows 10 Enterprise 641
Windows 7 Enterprise 644
1Not all features are available in all editions or versions of Windows. Systems might require upgraded and/or separately purchased hardware, drivers, software, or BIOS update to take full advantage of Windows functionality. Windows 10 automatic updates are always enabled. ISP fees might apply and additional requirements might apply over time for updates.
2This system is preinstalled with Windows 7 Pro software and also comes with a license and media for Windows 10 Pro software. Only one version of the Windows software can be used at a time. Switching between versions requires you to uninstall one version and install the other version. You must back up all data (files, photos, etc.) before uninstalling and installing operating systems to avoid loss of data.
3Some devices for academic use automatically update to Windows 10 Pro Education with the Windows 10 Anniversary Update. Features vary; for more information, see Windows 10 Pro Education features.
4Only available with 6th generation (Intel) processors.
Memory
Specification
DDR4-2400
Maximum: 64 GB
Number of slots: (2) DIMM (both slots are customer accessible/upgradeable)
Up to 2400 MT/s
Configurations
2048 MB total system memory (2048 MB x 1)
4096 MB total system memory (4096 MB x 1)
8192 MB total system memory (8192 MB x 1)
16384 MB total system memory (16384 MB x 1)
Addressing memory above 4 GB requires a 64-bit operating system. With Windows 32-bit operating systems, the amount of usable memory is dependent upon the configuration, therefore above 3 GB, all memory might not be available due to system resource requirements.
Memory modules support data transfer rates up to 2400 MT/s; actual data rate is determined by the system configured processor. See processor specifications for supported memory data rate.
Storage
Specification
SATA drives
500 GB, 7.2 K rpm, SATA 6.0 Gb/s, 6.35 cm (2.5 in)
1 TB, 7.2 K rpm, SATA 6.0 Gb/s, 6.35 cm (2.5 in)
500 GB, 7.2 K rpm, SATA 6.0 Gb/s, 8.89 cm (3.5 in)
1 TB, 7.2 K rpm, SATA 6.0 Gb/s, 8.89 cm (3.5 in)
2 TB, 7.2 K rpm, SATA 6.0 Gb/s, 8.89 cm (3.5 in)
Solid State Hybrid drives (SSHD)
500 GB, 5.4 K rpm, SATA 6.0 Gb/s, 6.35 cm (2.5 in), 8 GB Hybrid
1 TB, 5.4 K rpm, SATA 6.0 Gb/s, 6.35 cm (2.5 in), 8 GB Hybrid
1 TB, 7.2 K rpm, SATA, 8.89 cm (3.5 in), 8 GB Hybrid
Self-Encrypting drives (SED HDD)
500 GB, 7.2 K rpm, SATA 2.0 (3.0 Gb/s), 6.35 cm (2.5 in), SED Opal 2
SED SSD drives
256 GB, SATA (6.0 Gb/s), 6.35 cm (2.5 in), TLC SED SSD Opal 2
512 GB, SATA (6.0 Gb/s), 6.35 cm (2.5 in), TLC SED SSD Opal 2
PCIe NMVe TLC SSD drives
256 GB, PCI-E Gen3 x 4, Turbo Drive G2 TLC SSD
512 GB, PCI-E Gen3 x 4, Turbo Drive G2 TLC SSD
1 TB, PCI-E Gen3 x 4, Turbo Drive G2 TLC SSD
2.5 in SATA SSD drives
128 GB, SATA 3.2 (6.0 Gb/s), 6.35 cm (2.5 in), Non-SED SSD
256 GB, SATA 3.2 (6.0 Gb/s), 6.35 cm (2.5 in), Non-SED SSD
256 GB, SATA 3 (6.0 Gb/s), 6.35 cm (2.5 in), TLC SSD
512 GB, SATA 3 (6.0 Gb/s), 6.35 cm (2.5 in), TLC SSD
Optical disc drives
HP 9.5 mm (0.37 in) DVD Writer
HD-DVD discs cannot be played on this drive. No support for DVD-RAM. Actual speeds might vary. Copyright-protected materials should not be copied. Double layer discs can store more data than single layer discs. Discs burned with this drive might not be compatible with many existing single-layer DVD drives and players.
HP 9.5 mm (0.37 in) DVD-ROM
Media Card Reader (optional)
SD4 with 5-in-1 Interface from SD option to PCA is USB
Supports SD, SDXC, SDHC, UHS-I, UHS-II
Card sold separately.
For hard drives and solid state drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 30 GB of system disk is reserved for the system recovery software.
Networking/communications
Specification
Ethernet (RJ-45)
Integrated
Realtek RTL8111 HSH Gbe LOM network connection (standard)
Optional
Intel Ethernet I210-T1 PCIe x1 Gb Network Interface Card
Wireless LAN (WLAN) (optional)
Intel 7265 802.11ac 2x2 Wi-Fi with Bluetooth M.2 Combo Card non-VPro
Can be purchased later.
Intel 3168 802.11ac 2x2 Wi-Fi with Bluetooth M.2 Combo Card non-VPro
Wireless access point and Internet service required and not included. Availability of public wireless access points limited.
Audio/multimedia
Specification
Type
Conexant CX20632 Audio Codec (all ports are stereo)
Audio in/out ports
Headset1 front port, 3.5 mm (.14 in)
Line-out and line-in rear ports1, 3.5 mm (.14 in)
Internal speaker (standard)
Yes
2.0 W amplifier
Multi-streaming capable1
Yes
1The MT front headset connector supports CTIA style headsets. Headset connectors are retaskable to function as a Line-In, Microphone-In, Line-out, or Headphone-out port. Rear audio input ports are re-taskable as a Line-in or Microphone-in port. External speakers must be powered externally. Multi-streaming can be enabled in the audio control panel to allow independent audio streams to be sent to/from the separate connectors or internal speakers. This allows for different audio applications to use separate audio ports on the system. For example, the front connector can be used with a headset for a communications application while the rear connector is being used with external speakers and a multimedia application.
Power supply
Specification
80 PLUS Bronze
180 W active PFC; 82/85/82% efficient at 20/50/100% load (115 V)
310 W active PFC; 82/85/82% efficient at 20/50/100% load (115 V)
Operating voltage range
90 – 264 VAC
Rated voltage range
100 – 240 VAC
Rated line frequency
50 – 60 Hz
Operating line frequency
47 – 63 Hz
Rated input current
180 W/2.3 A
310 W/4 A
Rated input current with energy efficient1 power supply
4 A (310 W)
2.3 A (180 W)
DC output
+12 V
Current leakage (NFPA 99: 2102)
Less than 500 µA of leakage current at 120 VAC with the ground wire disconnected, as required for Non-patient Electrical Appliances and Equipment used in a patient care facility or that contact patients in normal use. Per section 10.3.5.1.
Less than 100 µA of leakage current at 120 VAC with the ground wire intact with normal polarity, as required for Non-patient Electrical Appliances and Equipment used in a patient care facility or that contact patients in normal use. Per section 10.3.5.1.
Power supply fan
70 mm variable speed
Power cord
1.83 m (6.0 ft)
1High efficiency power supply is a requirement for ENERGY STAR certification in conjunction with a select range of processors and modules.
Keyboards/pointing devices
Specification
Keyboards
HP Conferencing keyboard
HP USB PS/2 washable keyboard1
HP USB Business Slim keyboard
HP USB Business Slim CCID SmartCard keyboard
HP PS/2 Business Slim keyboard1
HP USB Business Slim keyboard (China only)
HP USB Business Slim grey keyboard
Mice
HP PS/2 mouse1
HP USB 1000 dpi laser mouse
HP Grey V2 mouse
HP USB mouse
HP USB PS/2 washable mouse1
HP USB mouse (China only)
HP USB hardened mouse
Combos
HP Wireless Business Slim keyboard and mouse1
HP USB keyboard and mouse (China only)
Mouse pad
HP mouse pad
1Optional HP Internal Serial/PS/2 ports are required to support this device.
Input/output devices
Specification
Optional ports (only one can be chosen)
HP DisplayPort port
HP Type-C port
HP HDMI port
HP VGA port
HP internal serial port
HP internal serial/PS/2 ports
HP PCIe x1 Parallel Port Card
HP PCIe x1 SuperSpeed USB 3.1 Gen 2 Type-C Card
Must be configured at purchase except for PCIe x1 cards.
Adapters and cables
Specification
Adapters
HP DisplayPort to DVI-D adapter
HP DisplayPort to HDMI 4K adapter
HP DisplayPort to VGA adapter
Cables
HP DisplayPort cable
HP DVI cable
Graphics
Specification
Intel HD Graphics (Integrated)
Intel Core i7 processor
Intel Core i5 processor
Intel Core i3 processor
Intel Pentium G4600T processor
Intel Pentium G4560T processor
Intel Celeron G3930T processor
Optional
AMD Radeon R7 450, 4 GB FH PCIe x16 (requires 310 W chassis)
AMD Radeon R7 460, 2 GB FH PCIe x16 (requires 310 W chassis)
Must be configured at purchase.
NVIDIA GeForce GT730, 1 GB PCIe x8 HDMI
NVIDIA GeForce GT730, 2 GB PCIe x8 DP
2nd Graphics Cards
AMD Radeon R7 450 4 GB FH PCIe x16 G5
Available only with AMD Radeon R7 450.
NVIDIA GeForce GT730 1 GB PCIe x8 HDMI
Available only with NVIDIA GeForce GT730 1 GB.
NVIDIA GeForce GT730 2 GB PCIe x8 DP
Available only with NVIDIA GeForce GT730 2 GB.
Ports/slots/bays
Specification
Ports
Standard
(4) USB 2.0: rear
(4) USB 3.1: (2) front, (2) rear
PS/2: optional
(1) DisplayPort
(1) VGA
(1) Headset, front
(1) Audio line-in, rear
(1) Audio line-out, rear
(1) RJ-45 Ethernet
Optional
(1) Serial (RS-232) and PS/2 combination (rear)
Internal
(3) Internal SATA storage connectors
(2) PCI Express x16 (v3.0); 1 wired as an x4
6.35 cm (4.2 in) full height
16.76 cm (6.6 in) length
35 W maximum power
(1) PCI
(1) Turbo Drive (M.2 PCIe)
(1) M.2 PCIe x1-2230 (for WLAN)
Bays
(1) 0.9 cm (0.35 in) Slim optical disc drive (ODD)
(1) 6.35 cm (2.5 in) internal storage drive
(2) 8.89 cm (3.5 in) internal storage drive
(1) Secure Digital (SD) 3 reader
MT can be configured with either (2) 3.5 in or (1) 3.5 in and (1) 2.5 in internal storage drive.
Security
Specification
Software security (standard)
Trusted Platform Module (TPM) 2.0 (Infineon SLB9670)
Common Criteria EAL4+ certified
Downgradeable to TPM 1.2
Convertible to FIPS 140-2 Certified mode (TPM 2.0 is not available for Win 7 32-bit) Restrictions apply; contact account manager for more details.
For more information about security software and features, go to the HP Client Security Software Suite webpage.
Hardware security
SATA 0,1 port disablement (via BIOS)
Serial, USB enable/disable (via BIOS)
Solenoid Hood Lock/intrusion sensor
Chassis padlocks and cable lock devices supported
Specification
BIOS
HP BIOSphere Gen3
Requires Intel or AMD 7th generation processors.
BIOS Update via Network
Master Boot Record Security
Power On Authentication
Secure Erase
For the methods outlined in the National Institute of Standards and Technology Special Publication 800-88.
Absolute Persistence Module1
Pre-boot Authentication
HP LAN-WLAN Protection
HP Wireless Wakeup
Communication/Connectivity
Native Miracast Support
Multimedia
Cyberlink Power Media Player (select models only)
Cyberlink Power2Go (select models only)
HP Value Add Software
HP ePrint Driver with JetAdvantage2
HP Hotkey Support – CMIT
HP Recovery Manager
HP Recovery Disc Creator (Windows 7 only)
HP Jumpstart
HP Support Assistant
HP Noise Cancellation Software
HP Velocity
HP Notifications
3rd party
Foxit PhantomPDF Express for HP (Windows 7 only)
Microsoft products
Buy Office
Bing Search
Skype (not available in China)
Manageability
HP Driver Packs (available for download)
HP Softpaq Download Manager (SDM)
HP System Software Download Manager (SSM) (available for download)
HP BIOS Config Utility (BCU) (subscription required)
HP Client Catalog (available for download)
HP Manageability & Integration Kit (MIK) (available for download)
LANDESK Management (subscription required)
For more information about manageability software, go to the HP Client Management Solutions webpage.
Client security software
HP Client Security
HP Security Manager (including Credential Manager and Password Manager)
HP DriveLock
HP Password Manager
HP WorkWise (requires Bluetooth)
Available soon as a free download on the App Store and Google Play. Requires Windows 10 Build 1607 or higher.
Microsoft
Microsoft Defender
Microsoft Security Essentials (Windows 7 only)
Opt-in and Internet connection required for updates.
1Absolute agent is activated when customers activate a purchased subscription. Subscriptions can be purchased for terms ranging multiple years. Service is limited, check with Absolute for availability outside the U.S. The Absolute Recovery Guarantee is a limited warranty. Certain conditions apply. Data Delete is an optional service provided by Absolute Software. If utilized, the Recovery Guarantee is null and void. In order to use the Data Delete service, customers must first sign a Pre-Authorization Agreement and either obtain a PIN or purchase one or more RSA SecurID tokens from Absolute Software.
2Requires an Internet connection to HP web-enabled printer and HP ePrint account registration. Requires optional broadband module. Broadband use requires separately purchased service contract. Check with service provider for coverage and availability in your area. Separately purchased data plans or usage fees might apply. Print times and connection speeds vary.
Physical specifications
Specification
Chassis (W x H x D) (not including bezel)
169.93 x 337.82 x 274.07 mm (6.69 x 13.30 x 10.79 in)
System volume
960 cu in
15.74 L
System weight
5.47 kg (12.06 lb)
Maximum supported weight (desktop orientation)
35 kg (77.16 lb)
Packaged (H x W x D)
499.11 x 389.89 x 297.94 mm (19.65 x 15.35 x 11.73 in)
Shipping weight
9.2 kg (20.28 lbs)
Palletization profile
6 units per layer; 7 layers maximum; 42 per pallet
1199.90 x 1000.00 x 2205.99 mm (47.24 x 39.37 x 86.85 in) including pallet
Environmental
Specification
ENERGY STAR
Certified models available
EPEAT
Registered where applicable/supported
Registration status varies by country/region.
TAA compliance
TAA compliant models available
