Specification
Type
IPS
Viewable image area
(diagonal)
68.58 cm (27.0 in) widescreen
Panel active area (W x H)
59.77 x 33.63 cm (23.53 x 13.24 in)
Resolution
1920 x 1080 at 60 Hz
note: |
Aspect ratio
16:9
Viewing angle
Up to 178° horizontal/178° vertical
Brightness
250 cd/m²
Contrast ratio (typical)¹
1000:1 static
5,000,000:1 dynamic (DCR)
Response times (typical)¹
Gray to gray: 5 ms
Pixel pitch
0.3114 (H) x 0.3114 (V) mm
Pixels per inch (PPI)
81.58 PPI
Default color temperature
6500K
Backlight lamp life (to half brightness)
30,000 hours minimum
Color gamut (typical)¹
72% sRGB
Color support
Displays up to 16.7 million colors
note:¹Actual performance varies.
