    Fix HP Printer issue on macOS
HP ProBook 640 G3 Notebook PC Product Specifications
Product image
Operating systems
Specification
Preinstalled
Windows 10 Pro 641
Windows 10 Home 641
NeoKylin Linux 64
FreeDOS 2.0
Web Supported
Windows 10 Enterprise 641
1Not all features are available in all editions or versions of Windows. Systems might require upgraded and/or separately purchased hardware, drivers, software or BIOS update to take full advantage of Windows functionality. Windows 10 automatic updates are always enabled. ISP fees might apply and additional requirements might apply over time for updates.
In accordance with Microsoft support policy, this product does not support Windows 8 or Windows 7. HP does not support the Windows 8 or Windows 7 operating system on products configured with Intel and AMD 7th generation or later processors, or provide any Windows 8 or Windows 7 drivers.
Processors
Specification
Intel Core i3-7100U
2.4 GHz
3 MB cache
2 cores
Intel Core i5-7200U
2.5 GHz (up to 3.1 GHz) with Intel Turbo Boost technology
3 MB cache
2 cores
Intel Core i5-7300U
2.6 GHz (up to 3.5 GHz) with Intel Turbo Boost technology
3 MB cache
2 cores
Intel Core i7-7600U
2.9 GHz (up to 3.9 GHz) with Intel Turbo Boost technology
4 MB cache
2 cores
Integrated with processor
Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. Performance and clock frequency vary depending on application workload and hardware and software configurations. Intel numbering is not a measurement of higher performance.
Processor speed denotes maximum performance mode; processors run at lower speeds in battery optimization mode.
Graphics
Specification
Integrated
Intel HD Graphics 620
HD content required to view HD images.
Discrete
AMD Radeon R7 M465 (2 GB GDDR5 dedicated memory)
AMD Dynamic Switchable Graphics technology requires an Intel processor and an AMD Radeon discrete graphics configuration. This technology is not available on FreeDOS and Linux OS. With AMD Dynamic Switchable Graphics technology, full enablement of all discrete graphics video and display features might not be supported on all systems (for example, OpenGL applications run on the integrated GPU or the APU as applicable). Available February 2016.
Specification
Internal
Non-touch
35.56 cm (14 in) diagonal LED-backlit HD SVA eDP Anti-glare Slim 45% CG 220 nits (1366 x 768)
35.56 cm (14 in) diagonal LED-backlit HD SVA eDP Anti-glare Slim 45% CG 220 nits (1366 x 768) with camera
35.56 cm (14 in) diagonal LED-backlit HD SVA eDP Anti-glare Slim 45% CG 220 nits (1366 x 768) with WWAN
35.56 cm (14 in) diagonal LED-backlit HD SVA eDP Anti-glare Slim 45% CG 220 nits (1366 x 768) with camera and WWAN
35.56 cm (14 in) diagonal LED-backlit FHD SVA eDP Anti-glare Slim 60% CG 300 nits (1920 x 1080)
35.56 cm (14 in) diagonal LED-backlit FHD SVA eDP Anti-glare Slim 60% CG 300 nits (1920 x 1080) with camera
35.56 cm (14 in) diagonal LED-backlit FHD SVA eDP Anti-glare Slim 60% CG 300 nits (1920 x 1080) with WWAN
35.56 cm (14 in) diagonal LED-backlit FHD SVA eDP Anti-glare Slim 60% CG 300 nits (1920 x 1080) with camera and WWAN
Touch
35.56 cm (14 in) diagonal LED-backlit FHD SVA eDP 60% CG 300 nits (1920 x 1080) with camera and WWAN
External
Up to 32-bit per pixel color depth
Display capabilities
VGA
Port supports resolutions up to 1900 x 1200 external resolution at 60 Hz
DisplayPort 1.2
Supports resolutions up to 2560 x 1600
30-bit color depth at 60 Hz
Full HD (1920 x 1080) monitors
24-bit color depth at 120 Hz
Resolutions are dependent upon monitor capability and resolution and color depth settings.
Number of displays supported with docking
Supports 3 independent displays if used with optional HP Ultraslim Docking Station.
Sold separately or as an optional feature.
Storage/drives
Specification
SATA, 6.35 cm (2.5 in) hard drives1
500 GB 7200 rpm Hard Drive
500 GB 7200 rpm SED Hard Drive (Opal 2)
500 GB 7200 rpm SED Hard Drive (Opal 2) (FIPS-140-2)
1 TB 5400 rpm Hard Drive
500 GB 5400 rpm Hybrid
M.2 (NGFF) 2280 solid state drive1
128 GB SATA-3 Value Solid State Drive
256 GB SATA-3 TLC Solid State Drive (Opal 2)
256 GB PCIe Gen3x4 NVMe TLC Solid State Drive
512 GB PCIe Gen3x4 NVMe TLC Solid State Drive
512 GB SATA TLC Solid State Drive (FIPS)
512 GB PCIe Gen3x4 NVMe TLC Solid State Drive (Opal 2)
Optical drives
Fixed 9.5 mm SATA
DVD-ROM Drive
DVD+/-RW SuperMulti DL
DVD-RAM cannot read or write to 2.6 GB Single-Sided/5.2 GB Double-Sided – Version 1.0 media.
Not available with Touch panel.
1For solid state drives or hard drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 30 GB is reserved for system recovery software.
Memory
Specification
Standard
DDDR4-2133 SDRAM (Transfer rates up to 1866 MT/s)
(2) SODIMM slots supporting dual-channel memory (both slots are customer accessible/upgradable)
Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory slots.
Configurations
4096 MB total system memory (4096 MB x 1)
8192 MB total system memory (4096 MB x 2)
8192 MB total system memory (8192 MB x 1)
12288 MB total system memory (8192 MB x 1 + 4096 MB x 1)
16384 MB total system memory (8192 MB x 2)
Maximum
Up to 16384 MB
Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility. If memory speeds are mixed, the system performs at the lower memory speed.
Networking/communication
Specification
Broadband Wireless (WWAN)2.3
HP lt4120 Qualcomm Snapdragon X5 LTE Mobile Broadband Module
HP lt4132 LTE/HSPA+ 4G Mobile Broadband Module
HP hs3210 HSPA+ Mobile Broadband Module
Wireless LAN (WLAN) via minicard1,2
Intel Dual Band Wireless-AC 3168 802.11a/b/g/n/ac (1x1) Wi-Fi and Bluetooth 4.2 Combo (non-vPro)
Realtek 802.11b/g/n (1x1) and Bluetooth 4.0 Combo (non-vPro)
Intel Dual Band Wireless-AC 7265 802.11a/b/g/n/ac (2x2) Wi-Fi and Bluetooth 4.2 Combo (non-vPro)
Personal area network (WPAN Bluetooth)1,2
Bluetooth 4.0 supported via Broadcom Realtek
Bluetooth 4.2 supported via all supported Intel WLAN modules
Near Field Communication (NFC)2
HP Module with NXP NFC Controller NPC100
Communications
Intel I219LM 10/100/1000 Ethernet
Intel I219V 10/100/1000 Ethernet
The term "10/100/1000" or "Gigabit" Ethernet indicates compatibility with IEEE standard 802.3ab for Gigabit Ethernet, and does not connote actual operating speed of 1 Gb/s. For high-speed transmission, connection to a Gigabit Ethernet server and network infrastructure is required.
Miracast supported (Windows 10)
1Wireless access point and Internet service is required and is not included. Availability of public wireless access points limited.
2Sold separately or as an optional feature.
3WWAN module is optional and requires a separately purchased service contract. Check with service provider for coverage and availability in your area. Connection speeds vary due to location, environment, network conditions, and other factors. 4G LTE is not available on all products, in all countries/regions.
Audio/multimedia
Specification
Audio
(2) Integrated audio speakers
Integrated digital microphone (Dual-microphone array when equipped with optional webcam)
Function keys for microphone mute, volume up, volume down
Stereo headphone/line out
Stereo microphone in
720p HD webcam (optional)
HD content required to view HD images. Sold separately or as an optional feature.
Keyboards/pointing devices/function keys
Specification
HP Premium keyboard
Keyboard features
Spill-resistant with drain (thin layer of Mylar film under the keyboard)
101/102-key compatible
Full-pitch key layout
DuraKeys (optional)
Backlit (optional)
DuraKeys only available with Backlit option.
Keyboard options
Touchpad, spill-resistant with drain
Touchpad, spill-resistant with drain, DuraKeys and Backlit
Dual Point, spill-resistant with drain, DuraKeys and Backlit
Touchpad
On/Off button
Enabled by default
2-finger scrolling
2-finger zoom (pinch)
OSD (enable/disable)
2-finger tap = right-click
Edge swipes
Function keys
Function keys
F1 – Sleep
F2 – Blank
F3 – Keyboard backlit toggle
F4 – Display switching
F5 – Brightness down
F6 – Brightness up
F7 – Blank
F8 – Volume down
F9 – Volume up
F10 – Microphone mute
F11 – Blank
F12 – Number lock
Power
Specification
Power supply1
Adapters
HP 45 W Smart AC Adapter
HP 45 W 2-prong Smart AC Adapter
HP 65 W Smart AC Adapter
HP 65 W Smart AC Adapter EM
HP 90 W Smart AC Adapter
Power cord
1.8 m, +/- 0.1 m (5.91 ft, +/- 0.33 ft)
1.0 m, +/- 0.1 m (3.28 ft, +/- 0.33 ft)
Primary battery
HP 3-cell Long Life Prismatic (48 WHr)
Battery is internal and not replaceable by customer.
1Availability might vary by country/region.
Ports/slots
Specification
Ports
(1) USB Type-C
(1) USB 3.0 port
(1) USB 3.0 port charging
(1) RJ-45/Ethernet
(1) Docking connector
(1) Headphone/microphone combo
(1) AC 4.5 mm (0.18 in)
(1) DisplayPort 1.2
(1) VGA port
Slots
(1) SD media reader slot (SD, SDHC, and SDXC supported)
Physical specification
Specification
Weight1
Starting at 1.95 kg (4.30 lbs)
3-cell battery, ODD weight saver, UMA, no FPR, (1) SODIMM, WLAN only, SSD, touchpad only, no camera, no WWAN
Dimensions (W x D x H)2
34.01 x 23.70 x 2.69 cm (13.39 x 9.33 x 1.06 in) (front and rear)
1Weight varies by configuration and components.
2Height varies depending upon where on the notebook the measurement is made.
Software/OS
Specification
BIOS
HP BIOSphere
Available only on business PCs with HP BIOS.
BIOS Update via Network
Master Boot Record Security
Power On Authentication
Secure Erase1
Absolute Persistence Module2
Pre-boot Authentication
Multimedia
CyberLink Power Media Player – CMIT
CyberLink Power2Go
Communication/Connectivity
HP Mobile Connect Pro (Windows 10 only)
Available on preconfigured devices with WWAN only.
Native Miracast Support
HP LAN-WLAN Protection
HP MAC Address Manager
HP Value Add Software
HP 3D DriveGuard (requires Windows)
HP ePrint Driver3
HP Hotkey Support – CMIT
HP Recovery Manager
HP Jumpstart
HP Support Assistant
HP Noise Cancellation Software
HP Image Assistant
HP Workwise
Available soon as a free download on the App Store and Google Play.
Microsoft Products
Buy Office
Bing Search
Skype (not available in China)
Manageability
HP Driver Packs (available for download)
HP SoftPaq Download Manager (SDM)
HP System Software Manager (SSM) (available for download)
HP BIOS Configuration Utility (BCU) (available for download)
HP Client Catalog (available for download)
HP Management Integration Kit for Microsoft SCCM (available for download)
LANDESK Management (subscription required)
For more information about manageability software, go to the HP Client Management Solutions webpage.
Client Security software
Microsoft Defender
HP Client Security Suite Gen3
HP Security Manager (including Credential Manager and Password Manager)
HP Drive Lock
HP Fingerprint Sensor
HP Password Manager
Security
Trusted Platform Module (TPM) 1.2 (Infineon SLB9670)
Common Criteria EAL4+ certified
Upgradable to TPM 2.0
This product ships with TPM 1.2. Option to upgrade to TPM 2.0 available via HP Customer Support.
Convertible to FIPS 140-2 Certified mode
HP Fingerprint Reader (On select models)
Security lock slot (Cable not included)
Integrated Smart Card Reader
For more information about security software and features, go to the HP Client Security Software Suite webpage.
1For the methods outlined in the National Institute of Standards and Technology Special Publication 800-88.
2Absolute agent is activated when customers activate a purchased subscription. Subscriptions can be purchased for terms ranging multiple years. Service is limited, check with Absolute for availability outside the U.S. The Absolute Recovery Guarantee is a limited warranty. Certain conditions apply. Data Delete is an optional service provided by Absolute Software. If utilized, the Recovery Guarantee is null and void. In order to use the Data Delete service, customers must first sign a Pre-Authorization Agreement and either obtain a PIN or purchase one or more RSA SecurID tokens from Absolute Software.
3Requires an Internet connection to HP web-enabled printer and HP ePrint account registration.
HP Cloud Recovery download tool (Cloud Recovery Client) is available under Software and Drivers section on the support page.
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
