Document ID: c05321678
Version: 2
HP Chromebook 11 G5 PCs - Error Appears Stating "Chrome OS Is Missing or Damaged" Please Insert a Recovery USB Stick or SD Card
Release date : 30-Oct-2016
Last updated : 14-Dec-2016
DESCRIPTION
When the computer is started, the following message is displayed:
Chrome OS is missing or damaged. Please insert a recovery USB stick or SD card.
When the Tab key is pressed, the following error code is displayed:
0x54 /0x08 TPM Read error in rewritable firmware.
SCOPE
The information in this document applies to the following:
Computers:
HP Chromebook 11 G5
Operating Systems:
Google Chrome, version 50.0.2661
RESOLUTION
To resolve this issue, follow the steps to download and install the Chrome OS update:
NOTE: The Chromebook automatically downloads software updates when it is powered on and connected to Wi-Fi. After an update is downloaded, it will need to be installed.
To check if an update is ready:
  1. Click the status area where your account picture is located.
  2. Locate the Update icon. (This icon appears only when an update is ready.)
  3. Click Update >Restart to update.
  4. Follow the onscreen instructions.
To check for and install updates before the next automatic update:
  2. Click Settings > About Chrome OS.
  3. In the About window, click Check for and apply updates. The Chromebook will install any available updates.
  5. After the updates are installed, click Restart to update.
  6. To confirm the Chromebook is up to date, click Settings > About Chrome OS.
NOTE: The solution is integrated in Chrome version 55.
Hardware platforms affected : HP Chromebook 11 G5
Support Communication Cross Reference ID : IA05321678
