HP LaserJet Enterprise 700 color MFP M775 - 13.8 stapler/stacker paper jam
Use the following procedure to clear paper jams in the stapler/stacker. When a jam occurs, the control panel might display a message and an animation that assists in clearing the jam.
  • 13.8X.XX – Stapler/Stacker Jam
  1. If paper is visible in the stapler/stacker output bin, grasp the leading edge of the paper and slowly pull the paper out of the product.
    Figure : Remove the jammed paper
  2. Open the stapler/stacker door.
    Figure : Open the upper-right door
  3. If jammed paper is visible, grasp both sides of the paper and slowly pull it out of the product.
  4. Lift up on the green tab to open the paper guide, and remove any jammed paper that is under the guide.
  5. Close the stapler/stacker door.
    Figure : Close the upper-right door
