HP LaserJet MFP M433, M436 - Printer features of the printer driver
You can use advanced printing features when using your machine. The following information describes the printer features you can access from the printer driver.
To take advantage of the printer features provided by your printer driver, click Properties or Preferences in the application’s Print window to change the print settings. The machine name that appears in the printer properties window may differ depending on the machine in use.
  • Some menus may not appear on the display depending on options or models. If so, it is not applicable to your machine.
  • Select the Help menu or click the button from the window or press F1 on your keyboard and click on any option you want to know about.
Item
Multiple Pages per Side
Selects the number of pages to print on a single sheet of paper.
Poster Printing
Prints a single-page document onto 4 (Poster 2x2), 9 (Poster 3x3), or 16 (Poster 4x4) sheets of paper, for the purpose of pasting the sheets together to form one poster-size document.
Booklet Printing
Prints your document on both sides of a sheet of paper and arranges the pages so that the paper can be folded in half after printing to produce a booklet.
  • If you want to make a booklet, you need to print on Letter, Legal, A4, US Folio, or Oficio sized print media.
  • The Booklet Printing option is not available for all paper sizes. Select the available paper Size option under the Paper tab to see what paper sizes are available.
  • If you select an unavailable paper size, this option can be automatically canceled. Select only available paper (paper without or mark).
  • Double-sided Printing
  • Double-sided Printing (Manual)
Print on both sides of a sheet of paper (duplex).
  • If your machine does not have a duplex unit, you should complete the printing job manually. The machine prints every other page of the document first. After that, a message appears on your computer.
  • Skip Blank Pages feature does not work when you select the Double-sided Printing (Manual) option.
  • Printer Default: If you select this option, this feature is determined by the settings you have selected on the control panel of the machine.
  • None: Disables this feature.
  • Long Edge: This option is the conventional layout used in bookbinding.
  • Short Edge: This option is the conventional layout used in calendars.
  • Reverse Double-Sided Printing: Check this option to reverse the print order when duplex printing. This option is not available when you use Double-sided Printing (Manual).
Paper Options
Changes the size of a document to appear larger or smaller on the printed page by entering in a percentage by which to enlarge or decrease the document.
Watermark
The watermark option allows you to print text over an existing document. For example, you use it when you want to have large gray letters reading “DRAFT” or “CONFIDENTIAL” printed diagonally across the first page or all pages of a document.
Watermark
(Creating a watermark)
  1. To change the print settings from your software application, access Printing Preferences.
  2. Click the Advanced tab, select Edit from the Watermark drop-down list. The Edit Watermarks window appears.
  3. Enter a text message in the Watermark Message box and Click OK.
    You can enter up to 256 characters. The message displays in the preview window.
Watermark
(Editing a watermark)
  3. Select the watermark you want to edit from the Current Watermarks list and change the watermark message and options.
  4. Click Update to save the changes.
  5. Click OK or Print until you exit the Print window.
Watermark
(Deleting a watermark)
  3. Select the watermark you want to delete from the Current Watermarks list and click Delete.
  4. Click OK or Print until you exit the Print window.
