    Apache Log4j Update
HP Notebook - 15-ba078dx (Touch) (ENERGY STAR) Product Specifications
Y5S37UA
AMD Quad-Core A10-9600P (2.4 GHz, up to 3.3 GHz, 2 MB cache)
6 GB DDR3L-1600 SDRAM (1 x 2 GB, 1 x 4 GB)
Video graphics
AMD Radeon R5 Graphics (up to 3.25 GB)
1 TB 5400 rpm SATA
Optical drive
SuperMulti DVD burner
15.6" diagonal HD SVA WLED-backlit touch screen (1366 x 768)
Keyboard
Full-size island-style with numeric keypad
Pointing device
802.11b/g/n (1x1)
1 USB 3.0; 2 USB 2.0; 1 HDMI; 1 RJ-45; 1 headphone/microphone combo
38.43 x 25.46 x 2.43 cm
2.14 kg
45 W AC power adapter
3-cell, 31 Wh Li-ion
VGA Webcam (front-facing) with integrated digital microphone
DTS Studio Sound™ with 2 speakers
HP ePrint; HP Games by WildTangent; HP Support Assistant; HP Connected Photo
Pre-installed software
Netflix; Dropbox; CyberLink Power Media Player; CyberLink PowerDirector; TripAdvisor
