    We are upgrading our website
HP ScanJet Pro 2000 s1, 3000 s3 - Scanner software (OS X)
The 3000 s3 model is compliant with Apple AirPrint-Scan functionality. Without installing any additional software, you can scan using Image Capture or other ICA-compliant applications.
To take advantage of all features of your scanner, HP recommends installing the HP provided scan solution, including HP Easy Scan and HP Utility. The following topics describe these items.
HP Easy Scan
Use HP Easy Scan to scan documents and photos, and manage scan shortcuts. Features include automatic photo detection, text recognition, PDF file output, and multi-page document processing. Use pre-configured scan shortcuts to quickly choose scan settings that are optimized for whatever you are scanning.
HP Utility
You can use the HP Utility when the scanner is connected with a USB cable.
The Maintenance pane in HP Utility displays the scanner usage, maintenance history, and notifies the user when maintenance is due. The notification displays in HP Utility when the Maintenance pane is selected.
HP Utility allows you to configure the scanner and assign the Scan button workflow on a Mac. HP Utility is available in the Applications > HP folder.
