    Fix HP Printer issue on macOS
HP EliteDisplay S240uj USB-C Wireless Charging Monitor - Specifications
Panel
Specification
Type
IPS with LED backlight
60.45 cm (23.8 in) widescreen
Panel active area (W x H)
52.57 x 29.57 cm (20.7 x 11.64 in)
Resolution
2560 x 1440 at 60 Hz
Aspect ratio
16:9
Viewing angle (typical)
Up to 178° horizontal/178° vertical (10:1 minimum contrast ratio)
Brightness (typical)*
300 cd/m²
Contrast ratio (typical)*
1000:1
Response rate (typical)*
5 ms gray to gray
Pixel pitch
0.20535 mm
Pixels per inch (PPI)
124 PPI
Backlight lamp life (to half brightness)*
30,000 hours minimum
Color gamut (typical)*
72%
Color support
Displays up to 16.7 million colors (With use of FRC technology)
All performance specifications represent the typical specifications provided by HP component manufacturers. Actual performance may vary.
User controls
Specification
Buttons or switches
Menu
Minus (–)/Swap USB host
Plus (+)/Color control
Exit/Next input
Power
Languages
English, Spanish, German, French, Italian, Dutch, Portuguese, Japanese, Traditional Chinese, and Simplified Chinese
On-screen display (OSD) user controls
Brightness, Contrast, Color control, Image control, Audio control, PIP control, Power control, OSD control, Management, Language, Information, Factory reset, USB host selection
Audio controls
Audio Follow Video, Volume, Bang & Olufsen, Internal Speaker Self-test
Signal interface/performance
Specification
Horizontal frequency
24 to 90 kHz
Vertical frequency
24 to 75 Hz
Native resolution
Preset VESA Graphic Modes (non-interlaced)
640 x 480 at 60 Hz
720 x 400 at 70 Hz
720 x 480 at 60 Hz
800 x 600 at 60 Hz
1024 x 768 at 60 Hz
1280 x 720 at 60 Hz
1280 x 768 at 60 Hz
1280 x 800 at 60 Hz
1280 x 960 at 60 Hz
1280 x 1024 at 60 Hz
1366 x 768 at 60 Hz
1440 x 900 at 60 Hz
1600 x 900 at 60 Hz
1600 x 1200 at 60 Hz
1680 x 1050 at 60 Hz
1920 x 1080 at 60 Hz
1920 x 1200 at 60 Hz
Maximum pixel clock speed
300 MHz
User programmable modes
Yes, 10
Anti-glare
Yes
Default color temperature
Native (Panel native)
Video/other inputs
Specification
Plug and play
Yes
Input signal
(1) HDMI/MHL
(1) DisplayPort 1.2
(1) USB-Type C (DisplayPort 1.2 Alt Mode)
HDCP support on HDMI, DisplayPort, and USB-Type C
USB
(3) USB 3.0 and (1) USB-Type C: (2) downstream and (2) upstream ports (1 B + 1 C)
Swap USB host
Yes (Upstream port B or Upstream port C)
Video cables included
(1) HDMI, 1.8 m (5.9 ft)
(1) MHL, 1.8 m (5.9 ft)
(1) DisplayPort, 1.8 m (5.9 ft)
(1) USB, 1.8 m (5.9 ft)
(1) USB-Type C, 1.8 m (5.9 ft)
Audio
Specification
System
Bang & Olufsen certified audio system
Output
Audio-out (headphone) jack
Speakers
Integrated 2 W per channel, Bang & Olufsen certified
Power
Specification
Power supply
External
Input power
19.5 V DC
Maximum power
148 W
Typical power
40 W
Power saving
0.5 W
Wireless charging
5 W Dual-mode (Qi and Airfuel Alliance inductive)
Power cable length
1.9 m (6.2 ft)
USB-Type C operating
Specification
Video support
USB-C Alt mode - DP video
USB
USB 3.1 Gen 1/5 G bps
Power outputs
5 V
5.25 V
9 V
12 V
15 V
20 V
3 A
60 W Max
Physical specifications
Specification
Dimensions (W × D × H)
With stand
54.06 x 21.34 x 42.9 cm (21.28 x 8.4 x 16.9 in)
Head only
54.06 x 4.43 x 34.6 cm (21.28 x 1.74 x 13.62 in)
With stand
5.5 kg (12.13 lb)
Head only
3.8 kg (8.38 lb)
Packaged
9.5 kg (20.94 lb)
Tilt Range
-5° to 21° vertical
Base
Attached, non-detachable
Bezel Color
Silver
Environmental
Specification
Temperature
Operating: 5° to 35° C (41° to 95° F)
Non-operating: –20° to 60° C (-4° to 140° F)
Humidity
Operating: 20% to 80% non-condensing
Non-operating: 5% to 95%, 38.7° C (101.66° F) max wet-bulb
Altitude
Operating: 0 to 5,000 m (0 to 16,404 ft)
Non-operating: 0 to 12,192 m (0 to 40,000 ft)
White LED backlights
Yes
CCFL panel
No
Arsenic-free display glass
Yes
Low halogen
Yes
Mercury-free display backlighting
Yes
Slots
Specification
Type
(1) Security lock slot
What's in the box?
Specification
Monitor and accessories
AC power cord, 1.9 m (6.2 ft)
HDMI cable, 1.8 m (5.9 ft)
MHL cable, 1.8 m (5.9 ft)
DisplayPort cable, 1.8 m (5.9 ft)
USB cable, 1.8 m (5.9 ft)
USB Type-C cable, 1.8 m (5.9 ft)
Documentation
CD and printed documentation
HP Display Assistant
