HP Pavilion Notebook - 15-ab245tu (Touch) Product Specifications
T0Z39PA
Intel® Core™ i5-6200U (2.3 GHz, up to 2.8 GHz, 3 MB cache, 2 cores)
8 GB DDR3L-1600 SDRAM (1 x 8 GB)
Video graphics
Intel® HD Graphics 520
1 TB 5400 rpm SATA
Optical drive
SuperMulti DVD burner
15.6" diagonal FHD UWVA eDP anti-glare WLED-backlit touch screen (1920 x 1080)
Keyboard
Full-size island-style keyboard with integrated numeric keypad
Pointing device
Intel 802.11a/b/g/n/ac (1x1) and Bluetooth® 4.0 combo (Miracast compatible)
1 HDMI; 1 headphone/microphone combo; 1 USB 2.0; 2 USB 3.0; 1 RJ-45
38.45 x 26.11 x 2.52 cm
2.49 kg
45 W AC power adapter
4-cell, 41 Wh Li-ion polymer
HP TrueVision HD Webcam (front-facing) with integrated digital microphone
B&O PLAY; Dual speakers
HP 3D DriveGuard; HP CoolSense; HP Recovery Manager; HP Support Assistant
Pre-installed software
Adobe® Shockwave® Player; CyberLink PhotoDirector; CyberLink PowerDirector; CyberLink YouCam; Evernote; User Guide documentation; Dropbox; CyberLink Power Media Player; iPass
Buy Office
