HP ENVY Notebook 15-as014wm (Touch) (ENERGY STAR) Product Specifications
W2K79UA
Intel® Core™ i7-6500U (2.5 GHz, up to 3.1 GHz, 4 MB cache, 2 cores)
8 GB DDR4-2133 SDRAM (1 x 8 GB)
Video graphics
  • Intel® HD Graphics 520 (up to 4.07 GB)
  • Integrated
  • 1 TB 5400 rpm SATA
  • [11]
15.6" diagonal FHD IPS UWVA multitouch-enabled edge-to-edge glass (1920 x 1080)
Keyboard
Full-size island-style backlit with numeric keypad
Pointing device
802.11ac (2x2) and Bluetooth® 4.0 combo
1 USB 3.0 (Type-C); 3 USB 3.0 (1 HP USB Boost); 1 HDMI; 1 headphone/microphone combo
38 x 25.5 x 1.79 cm
1.99 kg
45 W AC power adapter
3-cell, 52 Wh Li-ion
HP Wide Vision HD Camera with dual array digital microphone
Bang & Olufsen with 2 speakers
HP 3D DriveGuard; HP ePrint; HP Games by WildTangent; HP Support Assistant; HP Connected Photo
Pre-installed software
Netflix; Dropbox; CyberLink PowerDirector; TripAdvisor
