    We are upgrading our website
HP 280 G2 Small Form Factor PC - Specifications
Product image
Processors
Specification
Intel H110 chipset
Intel Celeron G3900 with Intel HD Graphics 510
2.8 GHz
2 MB cache
2 cores
Intel Pentium G4400 with Intel HD Graphics 510
3.3 GHz
3 MB cache
2 cores
Intel Core i3-6100 with Intel HD Graphics 530
3.7 GHz
3 MB cache
2 cores
Intel Core i5-6500 with Intel HD Graphics 530
3.2 GHz
6 MB cache
4 cores
Graphics
Specification
Integrated
Intel Integrated HD Graphics (Vary by processor)
Discrete
NVIDIA GeForce GT 730 2GB PCIe x8 (Optional, selected countries/regions only)
Memory
Specification
Form factor
Small form factor
Type
DDR4-2133 (Transfer rates up to 2133 MT/s)
Maximum
32 GB capacity
Number of slots
(2) DIMM
For systems configured with more than 3 GB of memory and a 32-bit operating system, all memory may not be available due to system resource requirements. Addressing memory above 4 GB requires a 64-bit operating system. Memory modules support data transfer rates up to 2133 MT/s; actual data rate is determined by the system configured processor. See processor specifications for supported memory data rate.
Storage
Specification
Hard drives
500 GB 7200 RPM SATA hard disk drive*
1 TB 7200 RPM SATA hard disk drive*
Solid state drives
128GB SATA Value SSD*
SD card reader
3-in1 SD media card reader
Optical disc drives
HP 9.5mm Desktop G2 Slim DVD-ROM drive
HP 9.5mm Desktop G2 Slim SuperMulti DVD Writer drive
Optical drives are optional or add-on features. Duplication of copyrighted material is strictly prohibited. Actual speeds may vary. Double layer media compatibility will widely vary with some home DVD players and DVD-ROM drives. Note that DVD-RAM cannot read or write to 2.6 GB single sided/5.2 double sided version 1.0 media.
*For hard drives and solid state drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 36 GB (for Windows 10) of system disk is reserved for the system recovery software.
Audio
Specification
Type
HD audio with Realtek ALC3252 Audio Codec
Microphone/headphone combo jack
Yes
Line-out and Line-in rear port (3.5mm)
Yes
Networking
Specification
Ethernet (RJ-45)
Realtek RTL8111HSH –CG: Integrated 10/100/1000M Gigabit Ethernet Controller supports Wake-on-LAN (WOL).
Wireless
Intel 3168 802.11ac with PCIe x1 WLAN/Bluetooth combo*
Intel 3168 802.11ac with PCIe x1 WLAN/Bluetooth combo disabled*
*Wireless cards are optional or add-on features and require separately purchased wireless access point and internet service. Availability of public wireless access points limited.
Ports/bays
Specification
Front in/out ports
(2) USB 3.0 ports
(1) Microphone/headphone combo jack
Rear in/out ports
(6) USB 2.0 ports
(1) RJ45 network connection
(1) Audio line out
(1) Audio line in
(1) VGA
(1) HDMI
Internal in/out ports
(1) PCIe x 16 (3.0)
(1) PCIe x 1 (2.0)
Bays
(1) 3.5 in Hard Disc Drive bay
(1) 9.5 mm Slim Optical Disc Drive bay
1) Secure Digital (SD) Reader bay
Keyboards and pointing devices
Specification
Keyboards
Business Slim USB Antimicrobial Standalone Wired Keyboard
HP USB Business Slim Keyboard
Mice
HP USB Mouse
HP USB Mouse (China only)
Keyboards and mice are optional or add-on features.
Physical specifications
Specification
Chassis (H x W x D)
100 x 270 x 290 mm (3.94 x 10.63 x 11.42 in)
3.5 in HDD: 4.03 kg (8.88 lbs)
2.5 in SSD: 3.66 kg (8. 07 lbs)
Software/OS
Specification
Preinstalled Windows
Windows 10 Pro 64
Not all features are available in all editions or versions of Windows. Systems may require upgraded and/or separately purchased hardware, drivers, software or BIOS update to take full advantage of Windows functionality. Windows 10 automatic updates are always enabled. ISP fees may apply and additional requirements may apply over time for updates.
Pre-installed (other)
FreeDOS 2.0
NeoKylin Linux 64-bit Commercial*
*Availability varies by country/region.
Web-supported
Windows 10 Pro 64
Environmental specifications
Specification
Temperature range
Operating: 10° to 35° C (50° to 95° F)*
Non-operating: -30° to 60° C (-22° to 140° F)
Operating temperature is de-rated 1° C per 300 m (984 ft) to 3000 m (9842 ft) above sea level, no direct sustained sunlight. Maximum rate of change is 10° C/Hr. The upper limit may be limited by the type and number of options installed.
Relative humidity
Operating: 10% to 90% (non-condensing at ambient)
Non-operating: 5% to 95% (non-condensing at ambient)
Maximum altitude (unpressurized)
Operating: 3048 m (10,000 ft)
Non-operating: 9144 m (30,000 ft)
Security features
Specification
Type
Trusted Platform Module (TPM) 2.0 (Firmware)
Security cable slot
