HP Sprocket - Using the HP Sprocket App
This document is for Android and Apple iOS devices with the HP sprocket app.
The HP sprocket app is the main software to use with your Sprocket. With this app, you can take and edit photos, print photos from your Sprocket, and reveal content that you have embedded in your printed photos.
 The HP sprocket app icon
Step 1: Install the HP sprocket app
Download and install the HP sprocket app on your mobile device.
  1. Download and install the HP sprocket app from the HP Sprocket (in English) homepage.
  2. Turn on the Sprocket.
  3. On your mobile device, open the Bluetooth settings menu, and then make sure Bluetooth is enabled.
  4. Open the HP sprocket app, select a startup option, and then continue to the next step.
Step 2: Print photos
Print photos using one of several available ways.
Review these frequently asked questions.
